<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Arduino Activ Line not visible]]></title><description><![CDATA[<p dir="auto">I have just installed the latest update 7.8.2 and the graphic color settings have not been hold by Npp.</p>
<p dir="auto">For an unknown reason, my Arduino program (the language is still defined as “Arduino”) has not the same colors than before the update: the active line (I mean the line where I type the words on the screen) is no longer visible: see attached screen capture.</p>
<p dir="auto">[URL][IMG]<a href="https://nsa40.casimages.com/img/2020/01/02/20010205233347999.jpg%5B/IMG%5D%5B/URL%5D" rel="nofollow ugc">https://nsa40.casimages.com/img/2020/01/02/20010205233347999.jpg[/IMG][/URL]</a></p>
<p dir="auto">How can i fix it ??</p>
<p dir="auto">thank you</p>
]]></description><link>https://community.notepad-plus-plus.org/topic/18696/arduino-activ-line-not-visible</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 10:00:12 GMT</lastBuildDate><atom:link href="https://community.notepad-plus-plus.org/topic/18696.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 02 Jan 2020 16:19:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Arduino Activ Line not visible on Fri, 03 Jan 2020 14:50:32 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much Peter !</p>
<p dir="auto">If I had knew that this update will put this mess, I would have kept my previous 7.8.1 version that was just perfect…</p>
<p dir="auto">By the way: Happy New Year !</p>
]]></description><link>https://community.notepad-plus-plus.org/post/49570</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/49570</guid><dc:creator><![CDATA[Elodie CEMOI]]></dc:creator><pubDate>Fri, 03 Jan 2020 14:50:32 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino Activ Line not visible on Thu, 02 Jan 2020 18:28:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elodie-cemoi" aria-label="Profile: Elodie-CEMOI">@<bdi>Elodie-CEMOI</bdi></a> said in <a href="/post/49556">Arduino Activ Line not visible</a>:</p>
<blockquote>
<p dir="auto">Can you tell me how to proceed to perform this reset ?</p>
</blockquote>
<p dir="auto">Sorry, you misunderstood.  I should have phrased it as “corruption” not “reset”. I said reset, because at least in some of the cases, some or all of the foreground colors get “reset” to black (which is the default foreground color when defining a UDL); in your case, the black foreground overtop your black background makes the text invisible.  The “reset” already happened, when it corrupted the file.</p>
<p dir="auto">At this point, if you do not have a backup copy of your UDL definition file (whether it was in the <code>userDefineLang.xml</code> or a file in the <code>userDefineLangs\</code> subfolder), then you just have to manually define the colors, the same as you did when you created the UDL.  This is why I said “you can use <strong>Language &gt; User Defined Language &gt; Define Your Language…</strong> to change the colors for a given language.”  (If you didn’t create the UDL, but got it from someone/somewhere else, go grab a new copy; that is your “backup”.)</p>
]]></description><link>https://community.notepad-plus-plus.org/post/49557</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/49557</guid><dc:creator><![CDATA[PeterJones]]></dc:creator><pubDate>Thu, 02 Jan 2020 18:28:29 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino Activ Line not visible on Thu, 02 Jan 2020 17:47:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Peter,</p>
<p dir="auto">You say <em>“There are instances (such as issue#5630) where UDL colorization gets reset under certain circumstances; so far, no fix has been found”.</em></p>
<p dir="auto">Can you tell me how to proceed to perform this reset ? because I am not an expert of N++ at all…</p>
<p dir="auto">Thank you,</p>
]]></description><link>https://community.notepad-plus-plus.org/post/49556</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/49556</guid><dc:creator><![CDATA[Elodie CEMOI]]></dc:creator><pubDate>Thu, 02 Jan 2020 17:47:55 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino Activ Line not visible on Thu, 02 Jan 2020 16:41:31 GMT]]></title><description><![CDATA[<p dir="auto">Oh, I forgot to say:</p>
<p dir="auto">There are instances (such as <a href="https://github.com/notepad-plus-plus/notepad-plus-plus/issues/5630" rel="nofollow ugc">issue#5630</a>) where UDL colorization gets reset under certain circumstances; so far, no fix has been found.  Sorry if this is what caused your color corruption.</p>
<p dir="auto">I personally recommend keeping each individual UDL in a separate XML in the <code>userDefineLangs</code> subfolder, and keep a backup of those (or keep it in version control, like I do), so if something gets corrupted, you can revert easily.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/49554</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/49554</guid><dc:creator><![CDATA[PeterJones]]></dc:creator><pubDate>Thu, 02 Jan 2020 16:41:31 GMT</pubDate></item><item><title><![CDATA[Reply to Arduino Activ Line not visible on Thu, 02 Jan 2020 16:37:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/elodie-cemoi" aria-label="Profile: Elodie-CEMOI">@<bdi>Elodie-CEMOI</bdi></a> ,</p>
<p dir="auto">Since there is no “Arduino Activ” language built in, I am assuming it’s a UDL.  With v7.8.2, you can use <strong>Language &gt; User Defined Language &gt; Define Your Language…</strong> to change the colors for a given language.</p>
<p dir="auto">The <a href="https://npp-user-manual.org/docs/user-defined-language-system/#udl-file-locations" rel="nofollow ugc">file that sets it</a> should either be in <strong>Language &gt; User Defined Language &gt; Open User Defined Language Folder…</strong>, or it should be in the parent directory to that one, as <code>userDefineLang.xml</code>.</p>
<p dir="auto">UDL References:</p>
<ul>
<li><a href="https://npp-user-manual.org/docs/user-defined-language-system/" rel="nofollow ugc">https://npp-user-manual.org/docs/user-defined-language-system/</a></li>
<li><a href="https://ivan-radic.github.io/udl-documentation/" rel="nofollow ugc">https://ivan-radic.github.io/udl-documentation/</a></li>
</ul>
<h3>Aside</h3>
<p dir="auto">The syntax for embedding images is not <code>[URL][IMG]https://nsa40.casimages.com/img/2020/01/02/20010205233347999.jpg[/IMG][/URL]</code>; it is <code>![](https://nsa40.casimages.com/img/2020/01/02/20010205233347999.jpg)</code>, which you could have seen by clicking the image button<br />
<img src="https://i.imgur.com/KOsSLNe.png" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">For others’ reference, the image that <a class="plugin-mentions-user plugin-mentions-a" href="/user/elodie-cemoi" aria-label="Profile: Elodie-CEMOI">@<bdi>Elodie-CEMOI</bdi></a> linked is:<br />
<img src="https://nsa40.casimages.com/img/2020/01/02/20010205233347999.jpg" alt="" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.notepad-plus-plus.org/post/49553</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/49553</guid><dc:creator><![CDATA[PeterJones]]></dc:creator><pubDate>Thu, 02 Jan 2020 16:37:30 GMT</pubDate></item></channel></rss>
