<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IDE for start with the publingtempleate]]></title><description><![CDATA[<p dir="auto">Hi every one</p>
<p dir="auto">I decide start with new plungin for notepad++ but my IDE (Visual Studio) can’t open, upload but tell me<br />
<img src="/assets/uploads/files/1590949238596-23993272-47cd-4a6a-9f39-826f9d843f9c-imagen.png" alt="23993272-47cd-4a6a-9f39-826f9d843f9c-imagen.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">In english<br />
Visual Studio tell me that I can’t admit thie project becouse don’t are compatible version of Visual Studio.</p>
<p dir="auto">What IDE and version you use and in with languaje(I try with C++)?</p>
<p dir="auto">Thanks for read</p>
]]></description><link>https://community.notepad-plus-plus.org/topic/19484/ide-for-start-with-the-publingtempleate</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 12:01:49 GMT</lastBuildDate><atom:link href="https://community.notepad-plus-plus.org/topic/19484.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 May 2020 18:26:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IDE for start with the publingtempleate on Sun, 31 May 2020 22:42:08 GMT]]></title><description><![CDATA[<p dir="auto">thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/ekopalypse" aria-label="Profile: Ekopalypse">@<bdi>Ekopalypse</bdi></a></p>
<p dir="auto">At final use my laptop with Visual Studio 2015, show me other problem.</p>
<p dir="auto">error TRK0005: no se encontró: “CL.exe”.<br />
(don’t find: “CL.exe”)</p>
<p dir="auto">Repair the VS 2015 select C++ and work.</p>
<p dir="auto">Install VS2015 in my computer and all ok.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/54480</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/54480</guid><dc:creator><![CDATA[Miguel M]]></dc:creator><pubDate>Sun, 31 May 2020 22:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to IDE for start with the publingtempleate on Sun, 31 May 2020 19:09:58 GMT]]></title><description><![CDATA[<p dir="auto">@Miguel-Menéndez</p>
<p dir="auto">if you open the vcxproj file with an editor, like npp :-) you can search for<br />
<a href="https://github.com/notepad-plus-plus/notepad-plus-plus/blob/master/PowerEditor/visual.net/notepadPlus.vcxproj#L31" rel="nofollow ugc">platformtoolset</a> and you will see that this is currently set to 141 which<br />
means Visual Studio 2017.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/54478</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/54478</guid><dc:creator><![CDATA[Ekopalypse]]></dc:creator><pubDate>Sun, 31 May 2020 19:09:58 GMT</pubDate></item></channel></rss>
