<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Search in files]]></title><description><![CDATA[<p dir="auto">Is this is a bug?<br />
Precondition: I have a file open in notepad++ and the file content is currently out of sync.<br />
Problem: When I search via find-in-files and the opened file is in the same folder, then only the out of sync content for this file is searched. I would expect that it is searched the complete content of the folder, independent what is open.</p>
]]></description><link>https://community.notepad-plus-plus.org/topic/20602/search-in-files</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 19:26:09 GMT</lastBuildDate><atom:link href="https://community.notepad-plus-plus.org/topic/20602.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Jan 2021 09:10:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 16:31:50 GMT]]></title><description><![CDATA[<p dir="auto">Searching the disk content of an open file is problematic…because, well, how does N++ do this type of searching?<br />
It opens the file into a tab that isn’t shown to the user, for each file searched.  Since it can’t easily open two tabs for the same file (hmmm, cloned view does it, though…?), this type of thing isn’t allowed.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61846</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61846</guid><dc:creator><![CDATA[Alan Kilborn]]></dc:creator><pubDate>Fri, 15 Jan 2021 16:31:50 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 16:02:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefan-vienna" aria-label="Profile: stefan-vienna">@<bdi>stefan-vienna</bdi></a> said in <a href="/post/61839">Search in files</a>:</p>
<blockquote>
<p dir="auto">But this is not intuitive</p>
</blockquote>
<p dir="auto">Oddly, to me, it would be <em>less</em> intuitive for a text editor’s “search” function to search the disk contents instead of what was actively in the editor (and in some cases – like a new file – be completely meaningless).</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61844</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61844</guid><dc:creator><![CDATA[PeterJones]]></dc:creator><pubDate>Fri, 15 Jan 2021 16:02:42 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 15:48:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello, <a class="plugin-mentions-user plugin-mentions-a" href="/user/stefan-vienna" aria-label="Profile: stefan-vienna">@<bdi>stefan-vienna</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/ekopalypse" aria-label="Profile: ekopalypse">@<bdi>ekopalypse</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/alan-kilborn" aria-label="Profile: alan-kilborn">@<bdi>alan-kilborn</bdi></a> and <strong>All</strong>,</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefan-vienna" aria-label="Profile: stefan-vienna">@<bdi>stefan-vienna</bdi></a> :</p>
<ul>
<li>
<p dir="auto">Open a <strong><code>CMD</code></strong> <strong>prompt</strong> window</p>
</li>
<li>
<p dir="auto">Type in the command  <strong><code>notepad++ -multiInst -nosession</code></strong> and valid</p>
</li>
</ul>
<p dir="auto">=&gt; A <strong>new</strong> N++ instance should open with, <strong>only</strong>, the <strong><code>new 1</code></strong> tab</p>
<ul>
<li>
<p dir="auto">Open the <strong><code>Find in Files</code></strong> dialog of that <strong>new</strong> instance</p>
</li>
<li>
<p dir="auto">Perform your searches</p>
</li>
</ul>
<p dir="auto">This time, it will search <em>ONLY</em>  inside true <strong>saved</strong> files, even if <strong>some</strong> of these are <strong>presently</strong> modified by an <strong>other</strong> N++ instance ;-))</p>
<p dir="auto">Best Regards,</p>
<p dir="auto">guy038</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61842</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61842</guid><dc:creator><![CDATA[guy038]]></dc:creator><pubDate>Fri, 15 Jan 2021 15:48:03 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 15:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ekopalypse" aria-label="Profile: Ekopalypse">@<bdi>Ekopalypse</bdi></a> aha ok. But this is not intuitive. For the open buffer exists the option “find in open files”</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61839</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61839</guid><dc:creator><![CDATA[stefan-vienna]]></dc:creator><pubDate>Fri, 15 Jan 2021 15:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 15:09:56 GMT]]></title><description><![CDATA[<p dir="auto">I am reading log files which are being constantly written.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61837</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61837</guid><dc:creator><![CDATA[stefan-vienna]]></dc:creator><pubDate>Fri, 15 Jan 2021 15:09:56 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 12:51:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefan-vienna" aria-label="Profile: stefan-vienna">@<bdi>stefan-vienna</bdi></a></p>
<p dir="auto">I suppose if you really want to search the saved-file and not the open-buffer, and you have no other good way of searching available to you (an independent utility of some sort, say), you could start another instance of N++ and use that to search it.</p>
<p dir="auto">For myself I rarely make a lot of changes to a file that I don’t intend to keep.  Thus I’m on the “save” key often.  Thus for me “saved-file” and “open-buffer” are the same thing, so I don’t run into the situation.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61827</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61827</guid><dc:creator><![CDATA[Alan Kilborn]]></dc:creator><pubDate>Fri, 15 Jan 2021 12:51:46 GMT</pubDate></item><item><title><![CDATA[Reply to Search in files on Fri, 15 Jan 2021 12:24:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stefan-vienna" aria-label="Profile: stefan-vienna">@<bdi>stefan-vienna</bdi></a></p>
<p dir="auto">it is expected, <em>open buffer beats saved file</em>.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/61826</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/61826</guid><dc:creator><![CDATA[Ekopalypse]]></dc:creator><pubDate>Fri, 15 Jan 2021 12:24:29 GMT</pubDate></item></channel></rss>
