<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Notepad++ new release 6.8.2 (Updated)]]></title><description><![CDATA[<p dir="auto"><a href="https://notepad-plus-plus.org/news/notepad-6.8.2-released.html" rel="nofollow ugc">https://notepad-plus-plus.org/news/notepad-6.8.2-released.html</a></p>
<p dir="auto">Edited on 02/09/2015:<br />
(tl;dr version: if you still got ‘<strong>&amp;</strong>’ not visible problem, use Style Configurator or remove stylers.xml to fix it)</p>
<p dir="auto">v6.8.2 fix the problem of Source Code Pro font by removing it.<br />
For people who still have the problem (for example: ‘<strong>&amp;</strong>’ is not visible), it’s due to your installed Source Code Pro font on your system, and here are 2 ways to remedy it:</p>
<ol>
<li>Use Style Configurator to set Default font as system font (Courier New).</li>
<li>Or remove stylers.xml so Notepad++ will regenerate it on startup.</li>
</ol>
<p dir="auto">Here are some explanations:</p>
<ul>
<li>
<p dir="auto">In v6.8 &amp; v6.8.1, Notepad++ Installer put Source Code Pro font in Notepad++ installed directory, load it then use it, without interfering with system.</p>
</li>
<li>
<p dir="auto">In v6.8.2, Installer removes Source Code Pro font if user upgrade from 6.8/6.8.1, and Notepad++ doesn’t load Source Code Pro font, but use only the font in stylers.xml. If Source Code Pro font is in stylers.xml and user has installed it before, then it will be used.</p>
</li>
<li>
<p dir="auto">stylers.xml will never be erased by installer since this file can be modified by users via Style Configurator.</p>
</li>
</ul>
<p dir="auto">Sorry for the inconvenience.</p>
]]></description><link>https://community.notepad-plus-plus.org/topic/8202/notepad-new-release-6-8-2-updated</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 23:24:41 GMT</lastBuildDate><atom:link href="https://community.notepad-plus-plus.org/topic/8202.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Aug 2015 14:28:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Thu, 09 Aug 2018 16:19:08 GMT]]></title><description><![CDATA[<p dir="auto">The developer only pays attention to any given “new release” thread in the Community Forums for a short while – and especially once he’s moved on to a newer version, he won’t be paying attention to the thread for an older version.</p>
<p dir="auto">If you want better tracking, follow <a href="https://notepad-plus-plus.org/community/topic/15741/faq-desk-feature-request" rel="nofollow ugc">this FAQ</a> to the <a href="https://github.com/notepad-plus-plus/notepad-plus-plus/issues" rel="nofollow ugc">Notepad++ Issues tracker on GitHub</a>.  You will want to search the existing issues (both open and closed) to make sure you aren’t repeating someone else’s request (I’ve seen this request multiple times).</p>
<p dir="auto">Even posting the request there, there is no guarantee that it will be implemented to your liking: he may choose to not implement any given feature request, and might not always close issues he’s privately rejected.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/34058</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/34058</guid><dc:creator><![CDATA[PeterJones]]></dc:creator><pubDate>Thu, 09 Aug 2018 16:19:08 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Thu, 09 Aug 2018 16:12:27 GMT]]></title><description><![CDATA[<p dir="auto">@Raul-Andres-del-Canto-Zahr said:</p>
<blockquote>
<p dir="auto">Hi.<br />
Always wondered why installer won’t remember the “don’t use %appData%” setting…</p>
</blockquote>
<p dir="auto">Hi, 3 year later and this hasn’t been fixed…</p>
]]></description><link>https://community.notepad-plus-plus.org/post/34057</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/34057</guid><dc:creator><![CDATA[SullyPanda76cl]]></dc:creator><pubDate>Thu, 09 Aug 2018 16:12:27 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Thu, 26 May 2016 14:03:42 GMT]]></title><description><![CDATA[<p dir="auto">Thank you. that fixed the issue (the &amp; (ampersand) not displaying one) on my pc.<br />
Notepadd++ v6.9.1. Windows 10.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/16117</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/16117</guid><dc:creator><![CDATA[RADHEY MEENA]]></dc:creator><pubDate>Thu, 26 May 2016 14:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Fri, 28 Aug 2015 12:33:47 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/donho" aria-label="Profile: donho">@<bdi>donho</bdi></a> … the <a href="https://notepad-plus-plus.org/temp/npp_deadLockFix2.zip" rel="nofollow ugc">https://notepad-plus-plus.org/temp/npp_deadLockFix2.zip</a> update resolved the ghost image issue.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10402</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10402</guid><dc:creator><![CDATA[nemgh]]></dc:creator><pubDate>Fri, 28 Aug 2015 12:33:47 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Thu, 27 Aug 2015 17:56:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi.<br />
]]></description><link>https://community.notepad-plus-plus.org/post/10398</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10398</guid><dc:creator><![CDATA[SullyPanda76cl]]></dc:creator><pubDate>Thu, 27 Aug 2015 17:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Thu, 27 Aug 2015 08:14:26 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for testing <a class="plugin-mentions-user plugin-mentions-a" href="/user/nemgh" aria-label="Profile: nemgh">@<bdi>nemgh</bdi></a> .</p>
<p dir="auto">I redo a fix here:<br />
<a href="https://notepad-plus-plus.org/temp/npp_deadLockFix2.zip" rel="nofollow ugc">https://notepad-plus-plus.org/temp/npp_deadLockFix2.zip</a></p>
<p dir="auto">Please try it and let me know the result.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10392</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10392</guid><dc:creator><![CDATA[donho]]></dc:creator><pubDate>Thu, 27 Aug 2015 08:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Fri, 28 Aug 2015 12:34:02 GMT]]></title><description><![CDATA[<p dir="auto">I see the same issue as Darrel Boyt above - v 6.8.2 - when I exit, the window stays on the screen, though the program is actually closed. I tried the update from donho (<a href="https://notepad-plus-plus.org/temp/npp.deadLockFixed.zip" rel="nofollow ugc">https://notepad-plus-plus.org/temp/npp.deadLockFixed.zip</a>) but the ghost image issue still exists.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10312</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10312</guid><dc:creator><![CDATA[nemgh]]></dc:creator><pubDate>Fri, 28 Aug 2015 12:34:02 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Wed, 26 Aug 2015 20:51:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/donho" aria-label="Profile: donho">@<bdi>donho</bdi></a> I’d love to, but the policies corporate put in place won’t let me.  Every time there’s a new release, I have to send a request up to corporate to unblock it.  I’ll try it on my home computer and let you know.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10307</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10307</guid><dc:creator><![CDATA[Darrel Boyt]]></dc:creator><pubDate>Wed, 26 Aug 2015 20:51:04 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Wed, 26 Aug 2015 17:59:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darrel-boyt" aria-label="Profile: Darrel-Boyt">@<bdi>Darrel-Boyt</bdi></a>  It’s fixed here:<br />
<a href="https://notepad-plus-plus.org/temp/npp.deadLockFixed.zip" rel="nofollow ugc">https://notepad-plus-plus.org/temp/npp.deadLockFixed.zip</a></p>
<p dir="auto">Could you test it and confirm me if this bug is fixed in the binary mentioned above?</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10301</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10301</guid><dc:creator><![CDATA[donho]]></dc:creator><pubDate>Wed, 26 Aug 2015 17:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Tue, 25 Aug 2015 17:59:24 GMT]]></title><description><![CDATA[<p dir="auto">Just updated to 6.8.2 and when I exit, the window stays on the screen, though the program is actually closed.  If I move another window over the image, the image is “erased”.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10076</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10076</guid><dc:creator><![CDATA[Darrel Boyt]]></dc:creator><pubDate>Tue, 25 Aug 2015 17:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Tue, 25 Aug 2015 13:26:31 GMT]]></title><description><![CDATA[<p dir="auto">BINGO!  I used the provided EXE by just replacing my current notepad++.exe.  The command I used above now works fine.  THANKS!</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10070</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10070</guid><dc:creator><![CDATA[VinsWorldcom]]></dc:creator><pubDate>Tue, 25 Aug 2015 13:26:31 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Tue, 25 Aug 2015 10:55:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vinsworldcom" aria-label="Profile: VinsWorldcom">@<bdi>VinsWorldcom</bdi></a>  Thank you for the bug report.<br />
I fixed the crash and you can open files with wild card via line command.<br />
Could you test the following binary and confirm me the bug is fixed?<br />
<a href="https://notepad-plus-plus.org/temp/npp.zip" rel="nofollow ugc">https://notepad-plus-plus.org/temp/npp.zip</a></p>
<p dir="auto">Don</p>
]]></description><link>https://community.notepad-plus-plus.org/post/10069</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/10069</guid><dc:creator><![CDATA[donho]]></dc:creator><pubDate>Tue, 25 Aug 2015 10:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to Notepad++ new release 6.8.2 (Updated) on Mon, 24 Aug 2015 19:07:53 GMT]]></title><description><![CDATA[<p dir="auto">I just hit a but on 6.8.2.  I tried to open the XML files from the Notepad++ directory:</p>
<p dir="auto">C:&gt; notepad++ \usr\bin\npp*.xml</p>
<p dir="auto">ACCESS VIOLATION!</p>
<p dir="auto">The above command works fine in 6.8.1.</p>
]]></description><link>https://community.notepad-plus-plus.org/post/9774</link><guid isPermaLink="true">https://community.notepad-plus-plus.org/post/9774</guid><dc:creator><![CDATA[VinsWorldcom]]></dc:creator><pubDate>Mon, 24 Aug 2015 19:07:53 GMT</pubDate></item></channel></rss>
