    Notepad++ v7.3 release
    23 Posts 15 Posters 47.4k Views
    • donhoD
      New 7.3 release which contains a MD5 generator is available :
      https://notepad-plus-plus.org/news/notepad-7.3-released.html
      happy hacking!
      • dailD
        dail
        Hi Don. Could you package the newer PluginManager (v1.4.3) with the 32-bit Notepad++ release? The past few N++ versions has downgraded the PluginManager to a prior version (v1.3.5) then always wants to re-update itself.
        Romano KasteelR 1 Reply Last reply Reply Quote 2
        • neilimeN
          neilime
          I’m using notepad++ x64 v7.3 on windows 7 ultimate x64, I cannot make notepad++ the default application for any files. The same issue appends for notepad++ v7.2, but was not fixed.
          Thank you.
          • cmeriauxC
            cmeriaux
            @donho in your new dialog “Generate MD5 digest” (md5Dlgs.rc) , the edit text “IDC_MD5_TEXT_EDIT” don’t print the “\n” : it prints only one line even if the clipboard contained multiple lines.
            • Romano KasteelR
              Romano Kasteel @dail
              @dail That’s also what I meant with https://notepad-plus-plus.org/community/topic/12801/notepad-v7-2-2-released/10
              • cmeriauxC
                cmeriaux
                @donho in your delivery repository, you have to update the PluginManager with the latest one. URL: https://github.com/bruderstein/nppPluginManager/releases/latest v1.4.3
                • batagyB
                  batagy
                  Hi Don,
                  And in addition to the PluginManager, it would be nice to include latest translations. I for example updated the Hungarian translation before the 7.3 release, but it was still not included in release. Thanks a lot for nice work!
                  • Mirek Paweł PiotrM
                    Mirek Paweł Piotr
                    Please add middle mouse button scroll possibility in main window (with scripts)
                    • chcgC
                      chcg
                      @donho For npp export plugin I created a github repo and update the code for x64 and current n++ plugin interface as jens lorenz seems to be inactive, see https://github.com/chcg/NPP_ExportPlugin/releases/tag/0.2.8.6 for a release from appveyor which you might include for x64
                      • Stephan MaucherS
                        Stephan Maucher
                        @donho Thanks for the new release.
                        Would it be possible to revise the config.xml “noAutoUpdate” setting?
                        I have outlined the issue here:
                        https://notepad-plus-plus.org/community/topic/12927/unattended-installation-auto-update-disabled
                        • area webbA
                          area webb
                          Hi, i’ve auto-updated today from v6.9 to v7.2 and cannot open windows network drives ( I’m not sure they’re called like this, I’m not using Window in english) - created when you go to My Computer and click ‘Add network drive’… so for example I have virtual drive Y: mapped to \\192.168.0.25\web . Notepad++ doesn’t show these when I go to Open -> My Computer .
                          Also doesn’t work from Explorer -> right-click -> Open with Notepad++
                          My OS is Win8.1 Pro x64.
                          Bye
                          • theodorejbT
                            theodorejb
                            I really wish Notepad++ would remember my scroll position when switching between tabs, rather than always jumping to the top of the file. Didn’t it use to do this in previous versions?
                            • Vitaliy DovganV
                              Vitaliy Dovgan
                              What about updating to latest version of Scintilla, by the way?
                              These 2 changes themselves makes me really want it! -
                              • Version 3.7.0 improves word selection, navigation, and manipulation for UTF-8 documents.
                              • Version 3.6.6 enables C++11 <regex> by default.
                              • cmeriauxC
                                cmeriaux
                                @area-webb check-out this post : https://notepad-plus-plus.org/community/topic/12688/scintilla-3-7-0
                                I released a completely experimental nightly build with Scintilla 3.7.0 embedded.
                                • chcgC
                                  chcg
                                  @Vitaliy-Dovgan n++ is using the regex functionality from boost, so c++11 regex wasn’t considered usefull as it just supports ECMAScript syntax, see http://www.cplusplus.com/reference/regex/ and not PCRE, see http://www.boost.org/doc/libs/1_55_0/libs/regex/doc/html/boost_regex/syntax.html and therefore notepad++ would loose functionality
                                  • David BaileyD
                                    David Bailey
                                    When I use MD5 /generate into clipboard, the result doesn’t match that obtained by running MD5sums (v 1.2) on the file itself. Maybe I have misunderstood what this does.
                                    If I use the MD5/generate option, the result is a rather bare dialog. I suppose it is obvious, but shouldn’t it say supply string for MD5?
                                    • donhoD
                                      donho @David Bailey
                                      @David-Bailey From what do you try to generate?
                                      From an unicode text?
                                      • David BaileyD
                                        David Bailey
                                        @donho Yes, NP++ encoding was (probably) set to UTF8 (without a BOM)
                                        David
                                        • Juan Manuel PedrosaJ
                                          Juan Manuel Pedrosa
                                          Hi, in the previous version, notepad could persist unsaved files when closed, now it requires that this files be saved or it won’t restore them on a new instance. Is this a desired behaviour?
                                          • Claudia FrankC
                                            Claudia Frank @Juan Manuel Pedrosa
                                            @Juan-Manuel-Pedrosa
                                            Check the following setting
                                            Settings->Preferences->Backup
                                            Is Remember current session for next launch and
                                            Enable session snapshot and periodic backup checked?
                                            Juan Manuel PedrosaJ 1 Reply Last reply Reply Quote 0
