    Double clicking over a word function works great, but it can be much greater than ever
    enhancement req
    27 Posts 4 Posters 8.9k Views 2 Watching
      PeterJones @Alan Kilborn
      @Alan-Kilborn said in Double clicking over a word function works great, but it can be much greater than ever:
      Maybe the Research Dept. will figure out the answer.
      • 7.0 from 2016 has Shortcut Mapper
      • 6.0 from 2012 has Shortcut Mapper
      • 4.0 from 2006 has Shortcut Mapper
      @W-TX joined May 21, 2019, when v7.7 (May 19) was brand new, and asked the earlier question in Nov 2019 (when v7.8.1 was the newest).
      Because I was curious:
      IiIiIGRvdWJsZWNsaWNrRXh0cmEucHkNCg0KaHR0cHM6Ly9jb21tdW5pdHkubm90
      ZXBhZC1wbHVzLXBsdXMub3JnL3RvcGljLzE5ODc5L2RvdWJsZS1jbGlja2luZy1v
      dmVyLWEtd29yZC1mdW5jdGlvbi13b3Jrcy1ncmVhdC1idXQtaXQtY2FuLWJlLW11
      Y2gtZ3JlYXRlci10aGFuLWV2ZXINCg0KSGlnaGphY2tzIHRoZSBkb3VibGUtY2xp
      Y2sgYWN0aW9uOg0KKiBzYXZlcyBjdXJyZW50IHNlbGVjdGlvbiBsb2NhdGlvbg0K
      KiBydW5zIEN0cmwrRjMgKFNlbGVjdCBhbmQgRmluZCBOZXh0KSB0byBnZXQgdGhl
      IGN1cnJlbnQgc2VsZWN0aW9uIGludG8gdGhlIHNlYXJjaCBidWZmZXINCiogZ29l
      cyBiYWNrIHRvIHRoZSBvcmlnaW5hbCBwb3NpdGlvbg0KKiBzZWFyY2hlcyBiYWNr
      d2FyZCBvbmNlIGFuZCBmb3J3YXJkIG9uY2UgdG8gcmUtYWN0aXZhdGUgYW55IHNt
      YXJ0bWF0Y2hlcw0KKiBBdCB0aGlzIHBvaW50LCB0aGUgYWN0aXZlIHNlbGVjdGlv
      biBpcyBpbiB0aGUgc2VhcmNoIGJ1ZmZlciBhbmQgRjMgd2lsbCB0YWtlIHlvdSB0
      byB0aGUgbmV4dCBpbnN0YW5jZS4NCg0KVG8gcnVuIGl0IGV2ZXJ5IHRpbWUsIHB1
      dCBpdCBpbiB5b3VyIHVzZXIgc2NyaXB0cyBmb2xkZXIgYXMgImRvdWJsZWNsaWNr
      RXh0cmEucHkiLCBhbmQgYWRkIHRoZSBmb2xsb3dpbmcgdG8geW91ciB1c2VyIHN0
      YXJ0dXAucHk6DQp+fn4NCmZyb20gTnBwIGltcG9ydCAqDQppbXBvcnQgc3lzDQpk
      ID0gbm90ZXBhZC5nZXRQbHVnaW5Db25maWdEaXIoKSArIHInXFB5dGhvblNjcmlw
      dFxTY3JpcHRzJw0KaWYgbm90IGQgaW4gc3lzLnBhdGg6DQogICAgc3lzLnBhdGgu
      YXBwZW5kKGQpDQoNCmltcG9ydCBkb3VibGVjbGlja0V4dHJhDQp+fn4NCg0KIiIi
      DQpmcm9tIE5wcCBpbXBvcnQgKg0KDQpkZWYgZG91YmxlY2xpY2tfZXh0cmEoYXJn
      cyk6DQogICAgc3MgPSBlZGl0b3IuZ2V0U2VsZWN0aW9uU3RhcnQoKQ0KICAgIHNl
      ID0gZWRpdG9yLmdldFNlbGVjdGlvbkVuZCgpDQogICAgbm90ZXBhZC5tZW51Q29t
      bWFuZCg0MzA0OCkgICMgc2VsZWN0IGFuZCBmaW5kIG5leHQgLi4uIGNhbm5vdCBm
      aW5kIHRoZSByaWdodCBNRU5VQ09NTUFORC5TRUFSQ0hfLi4uLiBlbnVtDQogICAg
      ZWRpdG9yLmdvdG9Qb3Moc2UpDQogICAgZWRpdG9yLnNldFNlbGVjdGlvbihzcyxz
      ZSkNCiAgICBub3RlcGFkLm1lbnVDb21tYW5kKE1FTlVDT01NQU5ELlNFQVJDSF9G
      SU5EUFJFVikNCiAgICBub3RlcGFkLm1lbnVDb21tYW5kKE1FTlVDT01NQU5ELlNF
      QVJDSF9GSU5ETkVYVCkNCg0KDQplZGl0b3IuY2FsbGJhY2soZG91YmxlY2xpY2tf
      ZXh0cmEsIFtTQ0lOVElMTEFOT1RJRklDQVRJT04uRE9VQkxFQ0xJQ0tdKQ0KDQoj
      IHVzZSBlZGl0b3IuY2xlYXJDYWxsYmFja3MoW1NDSU5USUxMQU5PVElGSUNBVElP
      Ti5ET1VCTEVDTElDS10pIGJlZm9yZSByZS1ydW5uaW5nIHRoaXMgc2NyaXB0IGR1
      cmluZyBkZWJ1Zw0K
      • W TXW Offline
        W TX @PeterJones
        @PeterJones said in Double clicking over a word function works great, but it can be much greater than ever:
        Further, Notepad++'s double-click behavior is the expected behavior, to anyone who has used MS Notepad, or MS Word, or any other word processing or text editing software I’ve used … and even other software, such as my web-browsers or my linux terminal programs: it selects the active word. Making it behave differently just in Notepad++, would break the expectation of many people.
        Here is my further thought that meets your practice custom and have nothing to change but will bring more convenience:
        1. Double clicking a word or highlighting a few words by pressing and moving cursor changes nothing. No code change.
        2. Press F3 key: if no words are highlighted, search is as usual; if words are highlighted, then the highlighted words becomes new search target. It does not change current Notepad++ user’s practice custom in following 2 situations:
        a. If a user continuously press F3 key, because when F3 key is pressed the target key is highlighted.
        b. If user moves cursor and types something, there is no highlighted word, press F3 key still keeps its search target words unchanged.
        The user practice custom only changes when double clicking or highlighting a few words by pressing and moving cursor and pressing F3 key, then the highlighted words will be used as new search target.
        It will save key strokes:
        You don’t have to use Ctrl+F to pop up the find window to enter new search target.
        You don’t have to use Ctrl+F3 to enter new search target, just use F3.
        It is a suggestion!
        W TXW PeterJonesP 2 Replies Last reply Reply Quote 0
        • W TXW Offline
          W TX @W TX
          @W-TX I am a hardware engineer and use Notepad++ to write VHDL coding. The most used functions are to search next and search back to make sure that any signal is properly used in any places. Textpad I used before has the design and when I turned to Notepad++, I immediately has the bad feeling about lacking the function. I think the code for the addition of F3 new function changes a little and everything is there: Pressing F3 moves the highlighted words into target buffer if they exist, and remains are unchanged.
            PeterJones @W TX
            @W-TX said in Double clicking over a word function works great, but it can be much greater than ever:
            That would still break my workflow – it’s changing the search target with my permission. F3 means “next of the current search”, not “change the search value and then find next”. If you want to change the search target in the same keystroke as find-next, then use Ctrl+F3 (you don’t need double-click). If you don’t like hitting Ctrl, then change the shortcut as has been described.
            I’ll give a hint: you might find what’s hidden in BASE64 to be of interest.
            W TXW 1 Reply Last reply Reply Quote 0
            • W TXW Offline
              W TX @PeterJones
              You cannot do it as you show when highlighted are words, not A word. You have to use Ctrl+F to bring up the find window! With my suggestion, you never have to do it.
              You said that it still change your workflow. It does not! If you do not highlight anything, nothing changes. If you highlight anything and press F3, then it changes.
                PeterJones @W TX
                Then that breaks my workflow. I don’t want highlighted text to change the search target when I hit F3. What if I have searched for XXX, then highlighted YYY for some other reason, then hit F3 to find the next XXX: with your description, it will try to find YYY instead. That’s not what I want.
                I am not going to argue this anymore. Just because it doesn’t bother you doesn’t mean it won’t bother anyone else.
                  Ekopalypse @PeterJones
                  Pj4+IE1FTlVDT01NQU5ELnZhbHVlc1s0MzA0OF0NCk5wcC5NRU5VQ09NTUFORC5TRUFSQ0hfU0VUQU5ERklORE5FWFQ
