    Notepad++ 7.9 RC3
    24 Posts 7 Posters 9.8k Views 1 Watching
      Hello @don-ho and All,
      With delay, many thanks for the new release ! Contrary to the other times, I can’t say that some points are especially interesting as all of them seem to be important ;-))
      Here are the contents of the v7.9 change.log file with the corresponding GitHub links, relative to each point. I certainly could miss some links but this list can be useful to shed some light on a particular point !
      Two remarks :
      • Point 14 : Add keyboard shortcuts for switching to panels should be changed as Add keyboard shortcuts for switching to Projects, Folder as Workspace and Function List panels as these shortcuts do not concern all panels !
      • I added these two points :
      28. Fix Escape key on FunctionList’s text field causing bell sound.
      29. Include newest nppPluginList in which HexEdit is updated to 0.9.7 (Fixed exception in v7.9 and supported 64 bits).
      Here is my new list :
      Notepad++ v7.9 Enhancements & bug-fixes:
      1.  Add the ability to open the target file of a Shortcut (*.lnk).
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8483
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8810
      2.  Enhance side panels behaviour: close a single panel instead of the entire stack.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8471
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8753
      3.  Fix Monitoring & document auto-update not scrolling to the end of the file with Word wrap enabled issue.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8850
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8851
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8214
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8477
      4.  Fix mouse cursor flicker while hovering URLs.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8588
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8641
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8647
      5.  Add back hovered blue underlined URLs.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8654
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8713
      ( https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8769 )
      6.  Enhance C++, Perl, Python parsers and add VHDL in Function List.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8480
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8509
      7.  Improve some ambiguous commands naming in Shortcut Mapper.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8689
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8690
      8.  Add an option to prevent right click from cancelling selection.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8563
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8564
      9.  Add ability to sort lines randomly.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8682
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8683
      10. Fix "Close All BUT this" looses current document data issue.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8617
      11. Allow user to start making a stream selection and then change to column block (by pressing ALT key).
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8555
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8557
      12. Add word wrap option to find results context menu.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8624
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8681
      13. Add keyboard navigation ability to Column Editor.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8488
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8569
      14. Add keyboard shortcuts for switching to panels.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8719
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8720
      15. Enable project panels toggle from menu.
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8533
      16. Enhance Folder as Workspace to restore latest selected item of last session on Notepad++ startup.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8353
      17. Fix inaccurate line margin update with word wrap enabled.
      https://github.com/notepad-plus-plus/notepad-plus-plus/commit/fe18e41d5d0895c481817bc3566f61f0056dc879
      18. Fix Find previous/next commands not scroll vertically to show match result issue (with word wrap disabled).
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8804
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8818
      19. Fix column key sort with col block starting in col1 bug.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8716
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8717
      20. Add confirmation preference for Replace All in All Opened Documents operation.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8527
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8708
      21. Add Escape keypress in functionlist searchbox to clear its text.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8667
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8789
      22. Add RTL capability to localized messageboxes.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8699
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8701
      23. Make (Find) dlgAlwaysVisible a true Preference setting.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/7908
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8651
      24. Fix sorting by column key using incorrect key values.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8674
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8675
      25. Add search scope to Find window status bar output.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8632
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8639
      26. Fix false hit result in Find in Finder.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8435
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8437
      27. Prevent redundant line data copy in Finder.
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8580
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8620
      https://github.com/notepad-plus-plus/notepad-plus-plus/commit/f3fce2de4a5bf17143af9df31e67f4162d215f70
      See  https://github.com/chcg/NPP_HexEdit/releases
      See also :
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8131
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8541
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/8696
      https://github.com/notepad-plus-plus/notepad-plus-plus/pull/8760
      https://github.com/notepad-plus-plus/notepad-plus-plus/issues/7638
        @guy038,
        Hi Guy,
        Nice to see you here again!
        Good point!
        However, after checking again this feature, I would reword it to Add keyboard shortcut ability to Projects, Folder as Workspace and Function List panels for switching among them. The term “ability” is used because the shortcuts are not added, but users can add them via Shortcut Mapper. What do you think?
        Escape key on FunctionList’s text field was added in v7.9, so the bug does not exist for the most of Notepad++ users (except us). So 28. is not meaningful in the change log.
        Same for 29.: Since the newest version of nppPluginList is always included on Notepad++ release, it’s not necessary to mention it each time. It was mentioned for the delta between RC2 and RC3 (for people in this forum), because of a crash bug of HexEdit detected on v7.9.
        Thank you for the list!
          Hi @don-ho and All,
          Don, you said :
          I would reword it to Add keyboard shortcut ability to Projects, Folder as Workspace and Function List panels for switching among them…
          Thank you for asking me my feeling about it ! After all, it’s your product, isn’t it ? But, indeed, this new phrasing seems more accurate !
          OK for messages about missing points 28 and 29, too !
          P.S. I’ll certainly duplicate this list, when N++ version 7.9 is announced :-)
            @guy038 said in Notepad++ 7.9 RC3:
            A product cannot go far without a great community.
            It’s always better to get people’s thinking to forge the direction of product.
            In this way, Notepad++ is rather a product of community, my role is just a filter to guide the product going more smoothly.
            Thank you everyone who’s contributed to this forum and to the project on GitHub!
