    Perl subroutine calltips - with PythonScript
    52 Posts 4 Posters 19.3k Views 2 Watching
      Ekopalypse @PeterJones
      can you give me a qiuck “Win32::Mechanize::NotepadPlusPlus for dummies äh ekopalypses” to open a new npp buffer?
        PeterJones @Ekopalypse
        @Ekopalypse ,
        From the command line, to just open a new file tab:
        perl -le "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"
        If you want to call a script.pl instead,
        notepad->newFile();
        But that assumes that perl has the right @INC (include library paths) to find Win32::Mechanize::NotepadPlusPlus.
          D:\perl\bin>perl D:\temp\perl\Win32-Mechanize-NotepadPlusPlus-0.005\Makefile.PL
          Could not open 'lib/Win32/Mechanize/NotepadPlusPlus.pm': No such file or directory at D:/perl/lib/ExtUtils/MM_Unix.pm line 2973.
          Now you know why I said “… for ekopalypses” ;-)
          PeterJonesP 2 Replies Last reply Reply Quote 1
            Ekopalypse
            hah, it is the other way around … from within the source call perl …
              @Ekopalypse said in Perl subroutine calltips - with PythonScript:
              For the installation, you need to be in the D:\temp\perl\Win32-Mechanize-NotepadPlusPlus-0.005\ directory, and run d:\perl\bin\perl Makefile.PL instead: you need to be in the same directory as the Makefile.PL, so that the relative paths are all correct.
                and then I used nmake to create the pm’s.
                I’ve copied the resulting Win32 to …/perl/lib/
                but now I get Can't locate Win32/API.pm in @INC (you may need to install the Win32::API module) (@INC contains: d:/perl/site/lib d:/perl/lib) at d:/perl/lib/Win32/Mechanize/NotepadPlusPlus/Notepad.pm line 9.
                  @Ekopalypse ,
                  The other thing I realized: you probably won’t have all the prerequisite modules installed. I normally use the cpanm utility, which distributes with strawberry perl, and that automatically downloads and installs prereqs before the module you’re trying to install. Without such a tool (and if you built your own perl, which I think you did to get the DLL), I don’t know that you have that.
                  I think the make process will tell you what prereqs you’re missing … but it’s been a long time since I’ve done a complicated manual install of a module.
                  Oh, yep, there, you posted the error while I was typing. You’re going to have to install at least Win32::API first… doing that manually is a pain.
                  When you built your own perl, did you at least get cpan, if not cpanm? I think one or both would be in the same directory as perl.exe… if you have cpanm, just do cpanm Win32::Mechanize::NotepadPlusPlus, and everything should work. If you have just cpan, I forget whether it handles prereqs; try cpan Win32::Mechanize::NotepadPlusPlus; if that’s not sufficient, do the missing prereqs one at a time with the cpan client. If you have neither… um… That’s going to be tough.
                  • Michael VincentM Online
                    Michael Vincent @PeterJones
                    @PeterJones said in Perl subroutine calltips - with PythonScript:
                    I believe it does - I normally just use CPAN and it fetches what I need to build.
                    Cheers.
                      Ekopalypse
                      I have cpan and it keeps installing stuff - did I choose to install the world??
                        Ekopalypse
                        it does this now since ~10 minutes
                          Ekopalypse
                          finished - but no Win32::API. started cpan Win32::API now.
                            Michael Vincent
                            @Ekopalypse
                            Is there a reason you build your own Perl? I have Strawberry 5.24 installed and doing this works:
                            That’s @Ekopalypse script from above using my “system” Strawberry Perl 5.24 DLL (the Perl that has my Win32::Mechanize::NotepadPlusPlus and all my other stull installed on it). Not sure why it’s printing “9” in the PythonScript console - is that what it’s supposed to do? I thought I’d get that string "print something ...
                            Cheers.
                              Ekopalypse @Michael Vincent
                              @Michael-Vincent
                              I get also 9 and from the function it seems correct to return an int.
                              See my previous post. RunPerl returns only an int. Not sure how to get the result (the print output), so far.
                                Michael Vincent @Ekopalypse
                                I get also 9
                                Oh, OK - great then. Seems I may be able to keep testing along without having to build a Perl and just use my Strawberry install.
                                Cheers.
                                  @Michael-Vincent
                                  My Win32::API has been built but not installed because of failing tests I guess. Can you try the "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();" and see what happens?
                                  Michael VincentM 2 Replies Last reply Reply Quote 1
                                      Can you try
                                      from ctypes import CDLL, POINTER, c_int, c_char_p
                                      perllib = CDLL(r'C:\Strawberry\perl\bin\perl524.dll')
                                      ["-le", "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"]
                                      perllib.RunPerl.restype = c_int
                                      perllib.RunPerl.argtypes = c_int, POINTER(c_char_p), POINTER(c_char_p)
                                      args = (c_char_p * 2)(b"-le", b"use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();")
                                      print(perllib.RunPerl(len(args),args, None))
                                      It just prints 9 in the PythonScript console. No new tab is opened. If I run the command itself from a prompt:
                                      C:\ > perl -e "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"
                                      I get a new tab in Notepad++ as expected.
                                      At least if it printed 42 we’d know we’re on to something …
                                      Cheers.
                                        Ekopalypse
                                        Ja, 42 would be nice :-)
                                        So 9 seems to be an error code.
                                          @Michael-Vincent
                                          Can you try one more thing?
                                          Replace the RunPerl call with this
                                          print(perllib.RunPerl(len(args), args, (c_char_p * 1)(b'')))
                                          With the newFile code, please.
                                            @Ekopalypse
                                            Same 9.
                                            I tried both:
                                            ["-e", "use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"]
                                            args = (c_char_p * 2)(b"-e", b"use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();")
                                            print(perllib.RunPerl(len(args),args,(c_char_p * 1)(b"use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();")))
                                            and
                                            print(perllib.RunPerl(len(args),args,(c_char_p * 1)(b'')))
                                            HOWEVER … this:
                                            ["use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();"]
                                            args = (c_char_p * 1)(b"use Win32::Mechanize::NotepadPlusPlus qw/:main/; notepad->newFile();")
                                            print(perllib.RunPerl(len(args),args,None))
                                            produces 0 in the PythonScript console.
                                            Cheers.
