    Notepad++ v8.2.1 Release
    40 Posts 14 Posters 16.1k Views
    • donhoD
      Notepad++ v8.2.1 Release is available here:
      https://notepad-plus-plus.org/news/v821-released/
      Notepad++ v8.2.1 new features and bug-fixes:
      1. Fix regression of loaded session being empty on exit. (Fix #10986)
      2. Add Find/Replace text swap button in Find replace dialog. (Fix #6010)
      3. Add an option for inserting auto-completion selection to fix hitting twice ENTER to go to next line. (Fix #4799, #4631, #8389, #10915)
      4. Fix installer x64 not detected the previous installation location. (Fix #7946)
      5. Add copy name/path commands to DocList and Edit menu. (Fix #10394)
      6. Fix Recent Files List not revised issue after “Save As” command. (Fix #10946)
      7. Fix Windows 11 detected wrongly issue in “Debug information”. (Fix #11011)
      8. Fix “Save As” command cannot be used as “Save” issue. (Fix #10965)
      9. Fix visual glitch regression of fg/bg color disabling. (Fix #11051)
      10. Fix wrong keywords (of preprocessor in C) highlighting in Java. (Fix #11026)
      Please let me know if any critical bug or regression is found.
      Auto-updater will be triggered in 1 week if there’s no critical issue found.
      • donhoD donho locked this topic on
      • donhoD donho pinned this topic on
      • donhoD donho unlocked this topic on
      • Syed BilalS
        Syed Bilal
        Unable to run it on Windows 11. See the screenshot: https://imgur.com/a/5ZPsh9O
        I am using Enterprise Edition (Activated)
        • Laze JanevL
          Laze Janev
          @syed-bilal The same in Windows 10
          • Laurent MontgomerL
            Laurent Montgomer
            I can’t open the app on Windows 11 Pro.
            • donhoD
              donho @Syed Bilal
              @syed-bilal @Laze-Janev @Laurent-Montgomer
              I can install the following package and run it under Windows11 with no problem:
              https://github.com/notepad-plus-plus/notepad-plus-plus/releases/download/v8.2.1/npp.8.2.1.Installer.x64.exe
              What’s the package did you download?
              Laze JanevL 3 Replies Last reply Reply Quote 1
              • Laze JanevL
                Laze Janev @donho
                @donho I was not able to run and returned back to 8.2. I’m on:
                Edition Windows 10 Pro
                Version 21H2
                Installed on ‎16.‎11.‎2021
                OS build 19044.1503
                Experience Windows Feature Experience Pack 120.2212.4170.0
                • Laze JanevL
                  Laze Janev @donho
                  • Laze JanevL
                    Laze Janev @donho
                    @donho I have tried again and it works now!
                    • OleksandrO
                      Oleksandr
                      OleksandrO 1 Reply Last reply Reply Quote 0
                      • OleksandrO
                        Oleksandr @Oleksandr
                          PeterJones @Oleksandr
                          @oleksandr ,
                          I’m sorry you are having difficulty with that. I am not sure whether your second post was meant to say, “nevermind, I got it working” (because it sure looks like you have it working), or whether you were showing a working version from some previous Notepad++ version. If it’s the latter, you will have to be more specific.
                          I just took a known-working UDL+autoCompletion custom pair of config files from v8.2, and copied those files into a portable v8.2.1 (and a portable v8.2.2-RC) instance. When I first tried to replicate, I wasn’t seeing any auto-completion (or specifically, Function Completion with Ctrl+Spacebar), and I thought I had replicated your problem in both. But I had closed Notepad++, and so when I went to get screenshots to add as evidence, they both started working the same as they did in v8.2 – so my simple UDL with an autoCompletion file with three keywords correctly shows me those three keywords when I Ctrl+Spacebar.
                          If you are still having difficulty with autoCompletion, you will need to give more details.
                          Amalan PhilipA 1 Reply Last reply Reply Quote 3
                          • winswGMBHW
                            winswGMBH
                            I don’t wish to discourage anyone but considering the number of issues being fixed or retriggered, should I be using latest versions or just stay on old version like before the x64 transition?
                            • Alan KilbornA
                              Alan Kilborn @winswGMBH
                              @winswgmbh said in Notepad++ v8.2.1 Release:
                              What is this quantity you are talking about?
                              I am using 8.2.1 for days now; no apparent problems.
                              That is something you have to answer for yourself.
                              winswGMBHW 1 Reply Last reply Reply Quote 0
                              • winswGMBHW
                                winswGMBH @Alan Kilborn
                                @alan-kilborn Ok. Quantity is the issues people report here since v 6.9.5. I am following up the community hence the question. I neither mean the things are not fixed(yes they are fixed) nor intend to disrespect the developer if that is what is concluded from my comment however most of the times I prefer “stability” over trying new features and updates. I am using this program for basic notepad tasks and code reading, nothing too complex and I prefer it as my default one always.
                                Stefan PendlS Lycan ThropeL 2 Replies Last reply Reply Quote 0
                                • Stefan PendlS
                                  Stefan Pendl @winswGMBH
                                  @winswgmbh
                                  if you use Notepad++ as a replacement for Notepad without doing fancy things, you can always update.
                                  I have never had any issues, since I too use Notepad++ in a similar way.
                                  • Lycan ThropeL
                                    Lycan Thrope @winswGMBH
                                    @winswgmbh ,
                                    I had the same experience as Stefan, until I decided to involve myself in creating a UDL for my community’s language. I even had a screwed up install with my x64 being installed in the x32 directory on windows, etc, and the program always worked for the simple things I did, bar none. So if you don’t want the latest and greatest, don’t upgrade, but don’t be afraid to upgrade for your modest needs. Things like the recent testing of files 2GB in size will not affect your usage and if it does, the testers will most likely find it before it becomes a release. Other than the broken update program a few version ago, I’ve not had one problem with the NPP that I didn’t create myself with my language creation. :)
                                    Lee
                                    Stefan PendlS 1 Reply Last reply Reply Quote 3
                                    • winswGMBHW
                                      winswGMBH
                                      @Stefan-Pendl and @Lycan-Thrope Thank you so much for clearing my doubts and hesitation to upgrade.
                                      • Stefan PendlS
                                        Stefan Pendl @Lycan Thrope
                                        @lycan-thrope
                                        I do use some UDLs for data files of a software I am maintaining and also never had any issues.
                                        It is the same for all kinds of software, an update or upgrade always has the risk to break something, this is why software vendors offer test releases.
                                        If you like to make sure your use-case works, use the portable release for testing it.
                                        • donhoD
                                          It seems v8.2.1 is quite stable.
                                          The auto-updater has been triggered for this release.
                                          • Amalan PhilipA
                                            Amalan Philip @PeterJones
                                            Hi @peterjones
                                            During the auto complete, the suggested words are listed in drop down. However, mouse click or keyboard navigation and selection using Enter key is not working. So, I had to downgrade to v8.2 to keep that auto-complete and keyboard navigation working.
