    Define multi-caret
    9 Posts 2 Posters 7.6k Views 1 Watching
    • Andrea GuglielmiA Offline
      Andrea Guglielmi
      I’m trying to find the “perfect editor” (for my needs) and after a looong test just two editors survived.
      Right now N++ become the preferred one as I found plugins for everything I was searching for (even if I would like something to be “embedded”) and the “killer feature” to use N++ as a notepad: open it, write and close it, no need to save anything and no annoying dialogs asking to save.
      Now, there is just one thing I miss from the other editor: ctrl-shift-click to set end for a multi-caret definition.
      Is there any way to do it that way?
      Thanks.
      • dailD Offline
        dail
        You mean like this? (The menu is from an older version but the functionality is the same)
        multedit
          Andrea Guglielmi
          Hi!
          No, i was not talking about “separated” multi-carets but instead of “alt-click and drag down” I would like to “click on the first row and ctrl-shift-click on the last one”.
          • dailD Offline
            dail
            I believe you want Shift+Alt+Click
            Andrea GuglielmiA 1 Reply Last reply Reply Quote 1
              Andrea Guglielmi @dail
              @dail YES!
                Andrea Guglielmi
                Once defined the multi-caret, is it possible to keep it defined while moving cursor around?
                • dailD Offline
                  dail
                  No, I don’t believe so.
                  Andrea GuglielmiA 1 Reply Last reply Reply Quote 0
                    Is there any place we can ask for some changes?
                    I would like to know if developers think to add features or if the “future” is just adding plugins.
                    I was searching for a way to copy/paste entire row when nothing is selected (I think is a Scintilla feature) and I found a plugin.
                    Thanks
                    • dailD Offline
                      dail
                      Either here or there is an actual issue tracker on GitHub.
                      Nobody is opposed to adding features as long as the majority of users will actually use it. It is very easy for a program to get bloated by tons of features only a few people will use. That’s why using a standalone plugin is nice because users can pick and choose what functionality they want. Also, the Notepad++ project does not add new features to Scintilla, it is just used as is. So if Scintilla doesn’t support a certain feature then Notepad++ won’t implement it.
                      I also use a plugin to do this. It is not enabled by default within Notepad++.
