    Not working Autocomplete when activated "Function parameters hint on input"
    autocompletionhintfunction hint
    5 Posts 2 Posters 4.8k Views
    • prontomP
      prontom
      When “Function parameters hint on input” checkbox activated and function hint is popup not work autocomplete inside function bracket. For example:
      $abc = 123;
      $abcde = 456;
      var_dump($abc
      here not apper autocomplete list
      • Claudia FrankC
        Claudia Frank @prontom
        Hello @prontom,
        for me it is working - see here.
        Which version do you use?
        Can you post the ?->debuginfo ?
        • prontomP
          prontom
          Sorry for late answer.
          In my case language is PHP screen1, screen2
          Debug info:
          Notepad++ v6.9
          Build time : Feb 21 2016 - 21:27:55
          Local Conf mode : ON
          OS : Windows XP
          Plugins : ComparePlugin.dll JSMinNPP.dll mimeTools.dll NppConverter.dll NppExport.dll NppFTP.dll PluginManager.dll
          • Claudia FrankC
            Claudia Frank
            From the scintilla docs,
            there is some interaction between call tips and autocompletion lists in that showing a call tip cancels any active autocompletion list, and vice versa.
            • prontomP
              prontom
              Thank you!
