    inserting ' and ', in long group of attributes
    7 Posts 3 Posters 9.9k Views 2 Watching
    • Ricardo Magalhães Mota FreitasR Offline
      may times i must insert ’ and ', in a long group of attributes, namelly a column from a sql query that i must search using operator “in” in another query…
      is there any way to do this in notepad++??
      Example:
      codea
      codeb b
      codec c c
      (1 thousand codes after)
      code1 2 10 20
      Adapt this to:
      ‘codea’,
      ‘codeb b’,
      ‘codec c c’,
      ‘code1 2 10 20’
      so that finally i can do this in sql server:
      select * from table1 where code in
      ‘codea’,
      ‘codeb b’,
      ‘codec c c’,
      ‘code1 2 10 20’
      Thank you and regards
        Claudia Frank @Ricardo Magalhães Mota Freitas
        Hello @Ricardo-Magalhães-Mota-Freitas,
        if this a column and you want to add a single quote in front and a single quote and a comma at the end of each line,
        then we could search and replace with regular expression like
        find what: ^(.+)$
        replace with: '\1',
        ^= start of the line
        $ = end of the line
        (.+) = match at least one char
        \1 = what got matched
          find what: ^(.+)$
          replace with: ‘\1’,
          $ = end of the line
          Jeeesus!
          Claudia thank you so much for your help :)
          i think i will live more 1 month in my life with this tip…
            Claudia Frank
            Glad to see that I helped to extend your life ;-D
              Hi, Ricardo and Claudia,
              The Claudia’s regex is quite correct. however, we can, even, shorten it !
              Find what    :  .+
              Replace with :  '$0',
              NOTES :
              In the replacement field, the syntax $n has two interesting properties :
              • The syntax $0 represents the entire searched match. So, in our example, the regex .+, that is to say, each non empty line. And the $0 syntax prevents us from surrounding the searched group with the normal two round brackets !
              • Contrary to the syntax \n ( with 1<=n<=9 ), which represents the contents of the searched groups 1 to 9, the syntax $n is valid, for any group, even higher than 9 !
              In the particular case, when the contents of the group n, must be followed, in replacement, with a digit, we just use the ${n} syntax, to separate the group designation, from the next digit. For instance, the following S/R, below :
              Find what    :  .+
              Replace with :  00${0}00
              would replace any non empty line of a file by the same line, surrounded by the string 00
                Claudia Frank @guy038
                Hey, guy038,
                tricky, but where does this $0 come from?
                  Hi, Claudia,
                  Just look the section Placeholder Sequences, from the Boost-Extended Format String Syntax article :
                  http://www.boost.org/doc/libs/1_48_0/libs/regex/doc/html/boost_regex/format/boost_format_syntax.html
                  Regards,
