    ? np++ is stuck on 14pt .
    5 Posts 3 Posters 4.0k Views 2 Watching
    • vmars vernonV Offline
      vmars vernon
      Hello & Thanks ,
      I’m having probs with Font Size :
      I am trying to get fontSize = 5pt .
      But np++ is stuck on 14pt .
      I have tried shutting it down , etc. .
      Pls , how can I un-stick it ?
      Thanks
        Hello vmars vernon,
        Could you tell use which N++ version do you use ? Just paste the infos, given from ? - Debug info, on the right part of the N++ Menu bar
        From memory, the font size 5, 6 and 7 were added , in the Style Configurator, from the version 6.1.6 !
        As for me, with the latest 6.9.0 version, it’s quite OK :-)
          vmars vernon
          Hi guy038 ,
          I am running version 6.8.3 .
          I don’t know what you mean here:
          ‘Defug info, on the right part of the N++ Menu bar’
          Thanks
            Hi, vmars vernon,
            Just click on the picture link, below, to understand what I meant :-)
            http://i.imgur.com/B5Oeirg.png
            • Jim DaileyJ Offline
              Jim Dailey
              In Settings->Style Configurator, In the Font Style section, do you have Enable global font size checked?
