    How do I highlight built-in variables in PHP that are not already highlighted?
    4 Posts 2 Posters 3.0k Views 2 Watching
    • Pete NorrisP Offline
      Pete Norris
      Hello Notepad++ forum!
      Question: How do I highlight built-in variables in PHP that are not already highlighted?
      I have noticed that variables like “real_escape_string” and “num_rows” are not highlighted.
      I have got Notepad++ version 6.9.2.
      Thank you in advance.
      • Jim DaileyJ Offline
        Jim Dailey
        @Pete-Norris You could try adding them to the Keywords section of the php Language in the langs.xml file.
          Pete Norris
          Jim;
          All I could find was langs.model.xml. It’s in the Notepad++ root directory (Notepad++\langs.model.xml)
          I added real_escape_string in the langs.model.xml file and it did not seem to work.
          Are there any other suggestions?
          Thanks.
            Jim Dailey
            @Pete-Norris My bad–wrong file. I have made additions to the C language section of the stylers.xml file. This allowed me to highlight various “words” with different highlighting.
            You should look for LexerType name=“php” and add your new keywords to whatever WordsStyle you want to be used to highlight them.
