    Marking And Highlighting shortcut
    8 Posts 2 Posters 10.5k Views
    • Harpreet Singh BassanH
      Is it possible to create my own shortcuts for Marking And or Highlighting any text with any style or just as standard style 1. By pressing the same should Clear it.
      Or Notepad++ can add it as standard of its own because they know what shortcuts are free.
      Thanks,
      • Claudia FrankC
        Claudia Frank @Harpreet Singh Bassan
        @Harpreet-Singh-Bassan
        If this requirement needs to be fulfilled, then no, not with builtin features.
        Otherwise use shortcut mapper and style configurator.
          I would like this request to be fulfilled please. I use it for programming Galil servo controllers instead of using their editor. It will be very handy to add these marking and highlighting feature with shortcut.
          • Claudia FrankC
            to get this solved now, I would recommend to use plugins like python/lua script to do it.
            Maybe someday npp supports it natively.
              O man. Thanks for some solutions at this time. BBBut both these two languages are the one I never have tried. Are there any example codes on line which I can just change little bit and do it. The latest one i have tried is Java but that too i am not as good. Or do you mind ----- please thro some codes here. Actually this will also the first time I will use any script in Notepad++. So how will I run script in Notepad++ . That will be a great help.
              • Claudia FrankC
                what languages do you prefer?
                There are other possible solutions like c# …
                For python you need to install the python script plugin.
                I would propose to use the MSI package instead of using the plugin manager.
                First steps are described here .
                An example script would be
                import re        # needed to find whole words only
                editor.indicSetStyle(13,INDICATORSTYLE.STRAIGHTBOX)                                 # used to color selected text
                editor.indicSetFore(13,(255,0,0))                                                   # the color in RGB color syntax
                editor.indicSetAlpha(13,155)                                                        # alpha settings
                editor.indicSetOutlineAlpha(13,255)                                                 # outlining
                editor.indicSetUnder(13,True)                                                       # draw under the text
                _g = globals()        # global variable used to check status
                if not _g.get('CUSTOM_STYLER_IS_RUNNING'):                                          # if variable not defined yet,
                    CUSTOM_STYLER_IS_RUNNING = False                                                # set it to False (=NOT RUNNING)
                def clear_indicators():                                                             # used to clear coloring
                    text_end_position = editor.getLength()                                          # determine document length
                    editor.setIndicatorCurrent(13)                                                  # set defined indicator
                    editor.indicatorClearRange(0, text_end_position)                                # and clear it from whole document.
                def colorize(text):        # used to color the selected chars
                    matches = []        # create empty list of matches
                    editor.research('\\b{0}\\b'.format(text), lambda m: matches.append(m.span(0)))  # find selected chars and append it to match list
                    for match in matches:                                                           # for each match found
                        editor.setIndicatorCurrent(13)                                              # set the defined indicator and
                        editor.indicatorFillRange(match[0], match[1] - match[0])                    # color it.
                def main():        # main function to handle start/stop behavior
                    global CUSTOM_STYLER_IS_RUNNING                                                 # assining to global variable
                    if CUSTOM_STYLER_IS_RUNNING:                                                    # if script is currently running
                        clear_indicators()                                                          # clear all inidcators and
                        CUSTOM_STYLER_IS_RUNNING = False                                            # set flag to False
                    else:        # else
                        selected_text = editor.getSelText()                                         # get selected text
                        if len(selected_text) > 0 and selected_text.isspace() == False:             # if there is at least on char selected
                            CUSTOM_STYLER_IS_RUNNING = True                                         # set the flag to true and
                            colorize(selected_text)                                                 # color the selection.
                main()        # entry point
                Other python scripts can be found here or in this forum.
                  Thanks Claudia. I use only cnc, plc, hmi, servo system programming the most. Other languages like C and visual basic are history for me. Java being new I still will prefer that. I use Eclipse for it. Any code help will be appreciated as otherwise I always try to work around.
                  • Claudia FrankC
                    Claudia Frank
                    Sorry, I’m not aware that there is an java automation plugin available.
                    So, maybe you wanna give the python example a try?
