Regain style coloring after saving a document
Hello Everybody,
Thank you in advance for the help,
So I would like to know how can I, after saving and closing a document, regain all text that I have colored by using the 5 styles (blue, orange, yellow, purple, green), because when I close the document after restarting it, I lose all text that i have colored in the document before.
Thank you again.
Up, any help please?
I don’t believe this is natively possible. Although certainly not what I would call simple, something like this could probably be adapted to make coloring persistent along the lines of what you are asking for:
https://notepad-plus-plus.org/community/topic/12085/hightlight-text-in-both-views/3 -
@Scott-Sumner In fact, I have done a search before, no result, hope that there is one solution, thank you for your reply =)
