    [vi simulator] how to highlight a word
    55 Posts 5 Posters 75.8k Views 4 Watching
      Scott Sumner @Claudia Frank
      @Claudia-Frank
      At one point I had some code in there to count the "if"s so that I could make sure they were all found by the search function…and I always saw a consistent and correct count.
        Claudia Frank @Scott Sumner
        @Scott-Sumner
        I can confirm, I run it 100 times and it always reported it correctly but there is another strange thing
        as soon as I put a print statement (which needs sys.stdout = console redirection) into the while loop I always get all "if"s colored. I even can now put the setIndicatorCurrent out of the loop.
        else:
            endPos = editor.getTextLength()
            temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, 0, endPos, 'if')
            editor.setIndicatorCurrent(indicator)
            console.clear()
            while temp != None:
                print temp
                (s, e) = temp
                editor.indicatorFillRange(s, e - s)
                temp = editor.findText(FINDOPTION.WHOLEWORD | FINDOPTION.MATCHCASE, e, endPos, 'if')
        print 'Done'
        First I thought about a timing issue but replacing the print statement with another time consuming action brings back the issue so … ???
          @Claudia-Frank
          Noticed that, too…sorry I didn’t mention it. :-)
            @Scott-Sumner, @dail
            I guess I found the reason. It’s basically what we already assumed. Npp is stepping in.
            During debugging I noticed, that sometime indicator was reset to value 29 (in such a case it was always 29),
            which, afaik, is used by smart highlighting.
            Albeit following code worked by 100 consecutive runs always, there is a potential risk that it fails again.
            while temp != None:
                (s, e) = temp
                if editor.getIndicatorCurrent() != indicator:
                    # print 'getIndicatorCurrent:{}'.format(editor.getIndicatorCurrent())
              Claudia Frank
              By the way, disabling smart highlighting doesn’t solve the issue because than another set indicator jumps in.
              • dailD Offline
                dail
                Probably the xml tag highlighting.
                  Claudia Frank @dail
                  @dail
                  correct, if we disable smart and matching tags highlighting then it works as expected
                  but this, at least for me, isn’t desirable.
                  • dailD Offline
                    dail
                    @Claudia-Frank
                    Oh I totally agree, it was just to prove it was caused by N++ :)
                    • Js jSJ Offline
                      Js jS
                      • Js jSJ Offline
                        Js jS
                        run this with the “if” block on screen
                        and again with the “if” block off screen
                        same result on “normal text” file
                        the “if” block has to be added
                        gets flagged as spam if i include it
                        from timeit import default_timer as timer
                        indicator = 12  # not sure what one is best to use but this works
                        editor.indicSetStyle       (indicator, INDICATORSTYLE.ROUNDBOX)
                        editor.indicSetAlpha       (indicator,  55)
                        editor.indicSetOutlineAlpha(indicator, 255)
                        first =  726
                        last  = 2260
                        start = timer()
                        for s in range( first, last, 3):
                            a=s
                            editor.indicatorFillRange(s, 2)
                        end = timer()
                        console.write("4:\t%f\n" % (end - start))
                        start = timer()
                            a=s
                            editor.indicatorClearRange(s, 2)
                        end = timer()
                        console.write("5:\t%f\n" % (end - start))
                        • Js jSJ Offline
                          Js jS
                          forgot to mention …
                          open python console
                          turning off brace matching and smart highlighting makes no difference
                          npp 7.3.1 32 bit windows7 64bit
                          • Js jSJ Offline
                            Js jS
                            addendum:
                            moving the mouse during the script execution causes misses in highlighting
                            Claudia FrankC S 2 Replies Last reply Reply Quote 0
                              Claudia Frank @Js jS
                              @Js-jS
                              for me it is hard to see to whom you want to address to.
                              May I ask you to add the name of the recipients to your post?
                              Concerning the post, I’m not quite sure what you try to impart.
                              Are you surprised about time differences?
                                Scott Sumner @Js jS
                                @Js-jS
                                I, too, am confused about what you are trying to demonstrate here. I’m more inclined to try code out if there is also a clear description about what it is doing that is odd or interesting. After reading such a description, I can decide if I want to try the code out or not (if there is something about it that is interesting to me…). Anyway, we kind of beat to death the “highlighting IFs” situation a couple of months ago…not sure what new there is to take away from it.
                                • Js jSJ Offline
                                  Js jS
                                  i was just adding my findings, in case anyone was still looking at this issue
                                  my knowledge is fairy limited, so i have not arrived to any real conclusion about the reason for the result
