    Solutions for manipulating columns of numbers, in tables, with regexes
    2 Posts 2 Posters 4.0k Views
    • guy038G
      Hi All,
      Here are below, some methods, relative at delimited range of numbers, placed in columns, which, I hope, could be useful to someone !
      So, let’s suppose that you have the simple delimited table, below :
      xxxxxxxxxxx    43        zzzzzzzz
      xxxxxxxxxxxxx  186519    zzzz
      xxxxxxxxxx     124071915 z
      xxxxxxxxxxxxxx 18711     zzz
      xxxxxxxxxx     7         zzzzzzz
      xxxxxxxxx      2025712   zz
      xxxxxxxxxxxxx  10399543  zzz
      xxxxxxxxxx     957       zzzzzzz
      xxxxxxxxxxxxx  1030117   zzzz
      xxxxxxxxxx     69        zzzzzzz
      xxxxxxxxxxx    10297881  zzzzzz
      xxxxxxxxxx     4320      zzzzz
      xxxxxxxxxx     0         zzzzzz
      xxxxxxxxxxxx   95082     zzz
      xxxxxxxxx      344613527 zz
      xxxxxxxxxxxxxx 885       zzzz
      xxxxxxxxx      1583      zzzzzz
      xxxxxxxx       347788    zzzzzzzzzzzz
      Now, you would like, of course, to align the different numbers to the right. Quite easy with the S/R, below, with regular expressions. So :
      • Firstly, find out the number of leading characters, before numbers. In our example, this number is 15
      • Use the following S/R, with the Regular expression search mode checked
        • SEARCH : (?-s)^.{15}\K(\d+)( +)(?= )
        • REPLACE : \2\1
      • Click on the Replace All button. Et voilà !
      => You should get the changed text, below :
      xxxxxxxxxx             0 zzzzzz
      IMPORTANT : This regex works fine, whatever the maximum number of digits is ( 9 digits, in our case )
      NOTES :
      • The first part (?-s) ensures that the regex engine will consider any dot symbol as a standard character, only
      • Then the second part ^.{15}\K select the first 15 characters of each line and reset the regex engine position just after them, due to the \K form
      • The third part (\d+) stores the non null range of digits in group 1
      • Finally, the part ( +)(?= ) stores, in group 2, any non null range of space characters, which must be followed by a space, due to the look-ahead structure (?= )
      • In replacement, the two groups are, just, swapped !
      Now, let’s suppose that the third column is quite far, on the right, like below :
      xxxxxxxxxx     0                                 zzzzzz
      Let M, the minimum number of characters between the digits and this third column ( M = 25, in our example )
      So, in addition to align the numbers to the right, you can adjust the preferred location of that column of digits, with the regex below, where 1<= N <= M-1
      SEARCH ^.{15}\K(\d+)( +)(?=( ){N}) ( Of course change the N variable by an integer ! )
      REPLACE \2\1
      For instance, if you use the search regex ^.{15}\K(\d+)( +)(?=( ){24}), the second column is the most closed to the first column, as below :
      xxxxxxxxxx              0                        zzzzzz
      And, if you use the search regex ^.{15}\K(\d+)( +)(?=( ){1}), the second column is the most closed to the third column, as below :
      xxxxxxxxxx                                     0 zzzzzz
      Now, an other general problem may happen : How to separate these numbers, with a comma, for instance, each thousand, as in the number 12,345,678
      So, let’s take again our first result of the alignment, above :
      xxxxxxxxxx             0 zzzzzz
      From this example, the comma or a space must be inserted :
      • Between the 21th and the 22th character of this table
      • Between the 18th and the 19th character of this table
      To do so, perform, successively, the two S/R, below :
      SEARCH (?-s)^.{20}\K((\d)(\d)|(.)(.))
      REPLACE (?2\2,\3:\4 \5)
      Then :
      SEARCH (?-s)^.{17}\K((\d)(\d)|(.)(.))
      At the end, you should get the formatted text, below :
      xxxxxxxxxxxxx      186,519 zzzz
      xxxxxxxxxx     124,071,915 z
      xxxxxxxxxxxxxx      18,711 zzz
      xxxxxxxxx        2,025,712 zz
      xxxxxxxxxxxxx   10,399,543 zzz
      xxxxxxxxxxxxx    1,030,117 zzzz
      xxxxxxxxxxx     10,297,881 zzzzzz
      xxxxxxxxxx           4,320 zzzzz
      xxxxxxxxxx               0 zzzzzz
      xxxxxxxxxxxx        95,082 zzz
      xxxxxxxxx      344,613,527 zz
      xxxxxxxxx            1,583 zzzzzz
      xxxxxxxx           347,788 zzzzzzzzzzzz
      NOTES :
      • Then, thanks to the part ^.{20}\K, we get rid of the first 20 characters of each line
      • The final part (?:(\d)(\d)|(.)(.)) tries to match two digits ( groups 1 and 2 ) OR two standard characters ( groups 3 and 4 )
      • If group 1 exists ( the digit ) we rewrite, in replacement, the two digits ( groups 1 and 2 ), separated by a comma sign
      • If group 1 is absent, we rewrite, in replacement, the two standard characters ( groups 3 and 4 ), separated by a space character
      REMARK :
      An other form, of the replacement regex, could be \1\3(?1,: )\2\4 :
      • This syntax is also correct, as the groups 1 and 3, as well as the groups 2 and 4, CANNOT exist at the same time. When one group exists the other does not Then, it’s just be replaced by a zero-length string
      • As above, due to the part (?1,: ), the separating character is a comma sign if group 1 exists ( the digit ) and a space character, on the contrary
      • Of course, you may change the comma sign, by any other symbol !
      • Vasile CarausV
        Vasile Caraus
        briliant !
