    Notepad++ and system colours
    colour theme
    1 Posts 1 Posters 2.4k Views 1 Watching
    • shane-rowleyS Offline
      shane-rowley
      I use a custom colour theme for Windows, a variation of the Win-98 theme because VB seems to misbehave using Vista, 7 or 8 themes. I also like dark themes. I’ve set the Windows theme, the menu to have a dark background with white text. In Notepad++, the tabs appear to be using the menu text colour (white for my theme), but the background is not the menu background colour, it is light grey, probably the window background. This means white text on a light background. I’d like it if the tabs text colour were not set to the menu text colour.
