    Notepad++ portable auto add "Open with Notepad++" in right click
    2 Posts 2 Posters 2.4k Views 1 Watching
    • ? Offline
      A Former User
      I’m using Notepad++ extracted from ZIP file as a portable to save disk space, and keep clean asap. Can you add a feature that auto add “Open with Notepad++” in right click?
        Scott Sumner @Guest
        @Dat-Tuan-Dinh-Rask-Mølle-Skole
        http://docs.notepad-plus-plus.org/index.php/Explorer_Context_Menu
