    Notepad++ 7.3.1 64-bit, default font style replace on small text
    3 Posts 2 Posters 2.4k Views 2 Watching
    • Liviu-Mihail ConcioiuL Offline
      I found an issue in Notepad++ 7.3.1, 64-bit version. The default font style I use for code editing is replaced only on a small fraction of code, where Norsk letters and other diacritics are. Also, over text it shows another text.
      Please see the image here http://tinypic.com/r/zufvyc/9
      Thank you,
      Liviu
        Claudia Frank @Liviu-Mihail Concioiu
        @Liviu-Mihail-Concioiu
        May I ask you to check with github issues
        and if needed open a new one?
          Hello Claudia,
          Checked the issues but wasn’t there and opened a new one.
          Thanks,
          Liviu
          With your input, this post could be even better đź’—
