    Suggest to have a hot-key for easily switch Word wrap function.
    3 Posts 3 Posters 3.7k Views 2 Watching
    • 陳宏達陳 Offline
      陳宏達
      Since the word-wrap function is very common used function to view long length text line.
      So I suggest to add it.
        Claudia Frank @陳宏達
        @陳宏達
        Settings->Shortcut Mapper->Main Menu
        search for Word wrap (line ~164) and set your shortcut.
        • Justin ReinaJ Offline
          Justin Reina
          My goodness this works great, thank you. I can’t believe I didn’t find this answer, what a solid feature.
          Thank you Claudia!
          -Justin
