    Display control characters as empty character or as spacing
    10 Posts 5 Posters 12.8k Views 3 Watching
    • NN---N Offline
      NN---
      Notepad++ uses Scintilla which displays control characters as rectangle with text.
      I want an option to not show these characters and to have option to replace it with space.
      I tried View->Show Symbol->Show whitespace and tabs
      But it didn’t help.
      Notepad++ still displays nul character as ‘NUL’.
      Is there option to do this ?
        If you have PythonScript plugin installed, go to the Plugins > PythonScript > Show Console and type:
        editor.clearRepresentation("\x00")
        in the >>> line, and hit RUN. This should make the NUL display as a blank character. To display NULs per NPP’s normal,
        editor.setRepresentation("\x00", "NUL")
        If that works for you, use the Plugins > PythonScript > New Script, create a script “Display NULs as SPACEs”, which contains just that first line. (I’d also make a second script “Display NULs as NUL” to be able to revert to normal display)
        If you use Plugins > Python Script > Configuration, you can then put those scripts into the main Macro menu, and using Settings > Shortcut Mapper > Plugin Commands, you can assign a keyboard shortcut to those scripts.
        • NN---N Offline
          NN---
          Thanks. I will check what the script does and just write a plugin or PR for N++.
          PythonScript doesn’t have 64-bit version.
            Alan Kilborn @NN---
            @NN—
            Why would you want to do this? Seems like you would just be hiding content, which sounds like a bad thing (without knowing more)
            • NN---N Offline
              NN---
              Notepad++ has huge performance issues when there are many control characters displayed.
              • V S RawatV Offline
                V S Rawat
                I also face problem about this.
                each character should have single char width.
                NUL, CR, LF become too long. And are actually ugly and horrifying looking.
                I wanted some invisible chars to be displayed but I got scared seeing them displayed in their current dress-up, so I had to stop displaying them.
                for every invisible character, please use a single char display method.
                like MS Word uses single chars for for paragraph mark and soft hyphen mark.
                Rawat
                  Hello, @nn and @v-s-rawat,
                  To replace all CO controls and C1 Controls by a specific character, you could also use a simple regex S/R
                  Refer to these special code-points, clicking on the links below :
                  http://www.unicode.org/charts/PDF/U0000.pdf
                  http://www.unicode.org/charts/PDF/U0080.pdf
                  So :
                  • For files with an ANSI encoding or a specific encoding ( Encoding > Character Sets > … ), use the following regex S/R :
                  SEARCH (?!\t|\r|\n)[\x00-\x1f]
                  REPLACE a SPACE ( or any other single character ! )
                  • For files with an Unicode encoding ( UTF-8, UTF-8 BOM, UCS-2 LE BOM and UCS-2 BE BOM, use, instead the S/R, below :
                  SEARCH (?!\t|\r|\n)[\x00-\x1f\x80-\x9f]
                  P.S. :
                  Of, course, due to the negative look-ahead (?!\t|\r|\n), any character replaced, at current position, must be :
                  • Different from the tabulation character ( \t )
                  • Different from the two End of Line characters ( \r and \n )
                  • NN---N Offline
                    NN---
                    Replacing is not a suitable solution since I have a log file which is changing each second.
                    I just want to see space instead of control character.
                    Seems like it is possible by calling API SCI_SETREPRESENTATION .
                      Hi, @nn,
                      Oh, I see ! Of course, my proposed static replacement is quite useless, in your case :-(( Sorry and… good luck for implementing the Scintilla API SCI_SETREPRESENTATION !
                        V S Rawat
                        I mean, if Replacing is the only solution,
                        hope someone develops a replacement table/ code that would change all control characters display to as used in MS Word/Excel.
                        Then it would be easy for us NON-programmer to use such a table.
                        Thanks.
