Issue using vertical scroll bar slider
I have encountered and issue using the vertical scroll bar slider. Dragging it all the way down to the bottom, does not scroll the file all the way to the end. It leaves a number of lines off the bottom of the screen. The larger the file, the more lines are left off. I was testing with files of 2,000 lines or more.
Thanks,
Rich
