C# NPP PLugin project template and demo problem
Has anyone successfully been able to build the examples for .NET plugins ? the latest example solution I see is VS 2010…
When I try to build either a project derived from the template or the example project - I get the error " system cannot find the file specified" - with reference to the <DllExportTask in NppPlugin.DllExport.Targets
please check the plugin forum, I remember there was a new package announced some time ago.
This is the C# template Claudia was referencing. It is newer, updated, and maintained.
