    function list doesn't work well for Python
    4 Posts 2 Posters 3.8k Views 1 Watching
    • pipielephant PiP Offline
      pipielephant Pi
      if more than three classes in a single, the last class will not show up in the
      function list. Look like a bug. Anyone has similar issues?
      N 1 Reply Last reply Reply Quote 0
        pipielephant Pi
        ok, figured out the problem. it is not an issue of the number of classes.
        You must make sure the last line of your file is “not indented”, else Npp
        will not consider it as a class.
        Hopefully this bug can be fixed in next release.
        • N Offline
          NippurDeLagash @pipielephant Pi
          Yes. Sometimes, derived classes do not have all methods listed correctly. It was something like
          class DerivedClass(BaseClass):
          class DerivedClass (BaseClass):
          The first line works well, the second does not. The only difference was the extra space between DerivedClass and (BaseClass).
          • N Offline
            NippurDeLagash
            Reported a function list issue here:
            https://github.com/notepad-plus-plus/notepad-plus-plus/issues/3706
