    shortcut to go to beginning/end of line
    6 Posts 3 Posters 45.8k Views 2 Watching
    • Sibo JiangS Offline
      Sibo Jiang
      In Rstudio, we can use Alt+ left/right arrow to go to either the beginning or end of the line.
      In notepad++, I can find such corresponding shortcut…
      Any tips on that?
      • AdrianHHHA Offline
        AdrianHHH
        Use the Home key for start of line. Repeated presses of Home toggle between start of line and first non-white-space character on the line. Use the End key for end of line.
        Use Control+Home and Control+End for start and end of buffer.
          Scott Sumner
          Also, Alt+Home is the default shortcut for moving to the absolute start of line.
            Sibo Jiang
            Thank you for the response. However, that home/end is definitely not as convenient as the Alt+left/right. Hope this feature can be added in future version.
              Scott Sumner @Sibo Jiang
              @Sibo-Jiang
              Why not use the Shortcut Mapper (see Settings menu), available since around 2005, to set your own preferred key combinations?:
              Imgur
                Sibo Jiang
                Thank you so much. That is a wonderful solution.
