    PluginIssue
    Scheduled Pinned Locked Moved Blogs
    7 Posts 3 Posters 27.6k Views 3 Watching
    • Jayanth NukalaJ Offline
      Jayanth Nukala
      Plugin Support on Notepad++ Latest version
      Team, I have installed V7.5.1 64 bit in windows 10 operating system. I tried include xml tools but I could not make use of it because of error.
      the specified module could not be found
      XMLTOOLS.dll is not compatible with the current version of notepad++.
      I have used V 2.4.9.2 for XMLTool.dll.
      Can you please guide me to refrain from error and help to use xml tools plug in in notepad V7.5.1 64 bit version
      • decodermanD Offline
        decoderman
        This might be the cause:
        From the download page:
        **Download 64-bit x64
        Note that the most of plugins (including Plugin Manager) are not yet available in x64 **
          Jayanth Nukala
          What do you suggest if i want xml tools in notepad++ in win 10 64 bit version os.
            decoderman
            Use 32 bit for these files or wait for whoever develops the plugin to release it for 64 bit.
            You can install both versions at the same time, I have it that way.
              Jayanth Nukala
              Thank you. Latest version of 32 bit also not including the xml tools plug in…I have to go previous version like 7.3.3.
                decoderman
                I’m on v7.5.1 and XML Tools v2.4.9.2 is available through the Plugin Manager.
                • MAPJe71M Offline
                  MAPJe71
                  Both 32 and 64 bits XMLTools plugin are available from here.
