    How to turn off auto-highlight on single click?
    settingshighlighting
    4 Posts 3 Posters 6.3k Views 3 Watching
    • Mark BratcherM Offline
      Mark Bratcher
      I am editing XML with default highlighting set. When I single click on a line to edit it, Notepad++ automatically highlights all of the attributes which by default seems to be very low contrast between background and foreground, making the text essentially unreadable.
      I have this issue with other languages as well.
      How do I turn off this highlighting?
      • decodermanD Offline
        decoderman
        Settings/Preferences/Highlighting, perhaps?
          Mark Bratcher
          OK thanks. I had tried everything under “Style Configurator” to attempt to adjust the colors, but that was to no avail. Going into Settings > Preferences > Highlighting I can simply disable that particular highlighting feature and make the problem go away by avoidance of the feature. That is what I originally asked for.
          However, it would be nice to have the highlighting, just done with sensbile colors. I could not find a setting for it.
            Claudia Frank @Mark Bratcher
            @Mark-Bratcher
            I assume smart highlighting is what you are looking for
