    Notedpad missing from the context of mouse right click
    12 Posts 3 Posters 16.6k Views 2 Watching
    • Zillah ZillahZ Offline
      Zillah Zillah
      Dear Experts
      I am using windows 10 not windows 7
      Right now I am missing Notepad ++ from the context of the mouse right click , uninstalled and installed didn’t fix the issue
      I have seen online couple of online solutions
      Applied and it didn’t fix the issue, I don’t know if I am missing something ?
      http://www.dhillonblog.com/2009/10/notepad-missing-from-context-menu-in-windows-7/
      Thx
        Claudia Frank @Zillah Zillah
        @Zillah-Zillah
        can you try using regsvr32 (check if the name is still correct, file should be under c:\windows.…)?
        Something like
        regsvr32.exe NppShell_06.dll
        Could be that you have to logout and login again to make it work.
        And I assume you have to execute it as administrator.
          Zillah Zillah
          Hi
          Attached error occurred
          https://imgur.com/a/DXzqu
            @Zillah-Zillah
            sorry, you must supply the installation path of notepad++.
            regsvr32.exe C:\Program ...\NppShell_06.dll
            if there are spaces within your path encase it with double quotes like
            regsvr32.exe "C:\Program ...\NppShell_06.dll"
            … of course must be replaced with your installation path.
            And the file NppShell_06.dll MUST be within the installation directory, of course - please double check if this is the case.
              Zillah Zillah
              Thanks Claudia for your help
              Installation path for my Notepad++ is
              C:\Program Files\Notepad++
              https://imgur.com/a/WItSP
              I executed the command (regsvr32) while I am in C:\Windows\System32 directory as shown in the screen shot below :
              https://imgur.com/a/nRPwf
              Am I missing something ?
              Thx
                @Zillah-Zillah
                Yes, my hint about the spaces in the path :-)
                Your call should look like this
                 regsvr32 "C:\Program Files\Notepad++\NppShell_06.dll"
                The double quotes are needed as some programs, like regsvr32, determine the parameters
                by using a space as a divider. By encasing in double quotes regsvr takes the whole path
                as one parameter.
                  Zillah Zillah
                  Thanks Claudia
                  Yes, my hint about the spaces in the path :-)<<
                  Although i did last time but I forgot to send you the snapshot.
                  Below is the screenshot with double quotes
                  https://imgur.com/a/nOSXI
                    @Zillah-Zillah
                    did you run this in an elevated command prompt?
                    As in Run as administrator?
                      Zillah Zillah
                      Let me try it again and see
                      Thx
                        Zillah Zillah
                        Thx
                        Yes Administrator’s privilege was missing and now it is completed successfully , restarted the computer still the option in the mouse right context is not there
                          @Zillah-Zillah
                          sorry but this means either MS has changed something in regards to shell extension or
                          your setup has something special about it.
                          And as I do not have Windows operating system anymore I cannot really try to find out
                          what is going on.
                          I’m sorry but I hope someone other with a Windows 10 Installation and knowledge about
                          what needs to be done reads this and picks up this question.
                          • ? Offline
                            A Former User
                            Just wanted to thank ZillaZilla for posting the problem. I learned from what you were having problems with. I had downloaded Notepad++ and expected it to work right off. Through your post I fixed it and it is working. The only problem was I took off work to do this assignment and wasted all day trying to get this to work.
                            Thanks again!!
