    Compiling Notepad++ -- How does one create and implement their own signature for a custom SciLexer.dll?
    3 Posts 2 Posters 1.7k Views 2 Watching
    • David Shuman235D Offline
      David Shuman235
      I am new to signed code and if I understand correctly the signature is the means being used to assure that a version (standard or custom) of Notepad++ is using the SciLexer.dll (standard or custom) compiled to work with it as well as to block hacks of SciLexer.dll. I created a custom Lexer for SQL code using a custom version of Notepad++ and need to create and implement as I understand it an appropriate signature to prevent my versions from being incorrectly used with other versions. Can anyone provide some guidance as to how to do this even a website and some hints where in Notepad"++ I will find the code that may need modification. – Thanks in advance.
        Scott Sumner @David Shuman235
        @David-Shuman235
        If you are just trying to get around the fact that the existing runtime check won’t let you run what you want to, you might have a look at @dail 's suggestion here about commenting out the call to VerifySignedLibrary().
          David Shuman235
          Sounds good.
          • that may be enough of a hint to go either way,
