    Comment command not working...
    8 Posts 5 Posters 2.9k Views 1 Watching
    • Mark -M Offline
      Mark -
      Since updating to 7.5.4, the comment menu commands do not work. CTRL+Q, right click and select any comment command, no joy.
      This feature worked in the last version I used.
      Language encoding set to Javascript. It worked when I tried Java and HTML.
      Notepad++ v7.5.4 (64-bit)
      Build time : Jan 1 2018 - 01:50:29
      Admin mode : ON
      OS : Windows 7 (64-bit)
      Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll
      Ideas?
      Mark
      • Mark -M Offline
        Mark -
        Just tested with 7.5.5, same problem.
        • Mark -M Offline
          Mark -
          After more testing it is the Notepad++ v7.5.4 (64-bit) version that does not work.
          I installed the Notepad++ v7.5.5 (32-bit) and the comments work.
          • Mark -M Offline
            Mark -
            Well I jumped the gun.
            I had to restore from backups to 6.7.1 to get the comments to work and have the styles I have configured to be correct.
            • sky 247S Offline
              sky 247
              • bay NzeerB Offline
                bay Nzeer
                1 Reply Last reply Reply Quote -4
                • Farah NAazF Offline
                  Farah NAaz
                  • muhammad muneebM Offline
                    muhammad muneeb
