    How do I tell Notepad++ to use spaces to auto-indent instead of tabs?
    5 Posts 3 Posters 29.1k Views 2 Watching
    • Kevin MorrisK Offline
      Kevin Morris
      Tabs are throwing off the tools that I copy Notepad++ text into. I need auto-indent to use spaces only. Thanks in advance for any help you can provide.
      • Meta ChuhM Offline
        Meta Chuh moderator @Kevin Morris
        @Kevin-Morris
        you can set spaces instead of tabs here:
          Kevin Morris
          For anyone who follows: Go to: Preferences, Language, over on the right there is a “Tab Settings” list box, below that is a “Change to space”. Put a check in that box.
            Scott Sumner
            I think the picture is better than the textual description. More complete, and doesn’t contain any errors of fact.
              @Kevin-Morris
              you’re welcome ;-)
