Navigation
    • Search
    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Search
    Project add Folder Reference
    General Discussion
    • wei zhang
      wei zhang last edited by
      The project has funciton to add files from folder. But it’s more convenient to add folder reference here.
      Claudia Frank 1 Reply Last reply Reply Quote 0
      • Claudia Frank
        Claudia Frank @wei zhang last edited by
        @wei-zhang
        ??? - if you right click on your project you can add folder, files or files from dictionary.
        What else are you expecting?
        Or do you refer to the folder as workspace functionality which is also available?
        Might it be that you do have an really outdated npp version?
