    How to separate specific text with notepad?
    22 Posts 4 Posters 16.8k Views 1 Watching
      Hello, @yuly-pmem, @ani-rodet, @terry-r and All,
      Ah OK ! So, here are, below, all the regexes to achieve the suppression of 1 or 2 columns, from an original 3-columns table, separated with colons ( : )
      Let’s imagine the initial 3-columns table, below :
      cell A1:cell B1:cell C1
      cell A2:cell B2:cell C2
      cell A3:cell B3:cell C3
      Then :
      • With the regex S/R :
      SEARCH :[^:\r\n]+$
      REPLACE Leave EMPTY
      Only columns A and B remain :
      cell A1:cell B1
      cell A2:cell B2
      cell A3:cell B3
      SEARCH (?-s):.+(?=:)
      REPLACE Leave EMPTY
      Only columns A and C remain :
      cell A1:cell C1
      cell A2:cell C2
      cell A3:cell C3
      SEARCH (?-s)^.+?:(?=.+:)
      REPLACE Leave EMPTY
      Only columns B and C remain :
      cell B1:cell C1
      cell B2:cell C2
      cell B3:cell C3
      SEARCH (?-s):.+$
      REPLACE Leave EMPTY
      Only column A remains :
      cell A1
      cell A2
      cell A3
      SEARCH (?-s).+:(.+):.+
      REPLACE \1
      Only column B remains :
      cell B1
      cell B2
      cell B3
      SEARCH (?-s)^.+:
      REPLACE Leave EMPTY
      Only column C remains :
      cell C1
      cell C2
      cell C3
      • yuly pmemY Offline
        yuly pmem
        @guy038 said:
        @terry-r
        I am very grateful for your help friends (guy038, terry), they are the maximum
        thank you teachers
        they work perfectly
