    Problem with syntax highlighting
    3 Posts 2 Posters 1.4k Views 2 Watching
    • niente0N Offline
      niente0
      Hi, in the latest version of Notepad++ (v7.5.4) there’s a bug related to syntax highlighting.
      If I double-click on an asp file Notepad++ opens it but syntax is not highlighted as usual.
      But if I close the window and double-click again on the same file, this time it opens correctly and syntax is highlighted.
      Can you please check and fix this problem?
      Thank you
        v7.5.4 is not the latest version. Version 7.5.8 was released July 23. If you go to https://notepad-plus-plus.org/download/ , you can always see what the most recent version is.
        This FAQ will explain where to make a bug report so that the developers will actually take note.
        • niente0N Offline
          niente0
          Hello, I updated Notepad++ to the latest version and it seems to work ok!!
          Thank you :-)
