    Not able to print
    2 Posts 2 Posters 1.0k Views 2 Watching
    • Darrell BradleyD Offline
      Darrell Bradley
      FYI, when pressing the print button, Notepad++ closes and does not print.
      Notepad++ v7.5.8 (64-bit)
      Build time : Jul 23 2018 - 02:06:36
      OS : Windows 10 (64-bit)
      Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll
        Per this other thread, you may need to create the %APPDATA%/notepad++/plugins/ directory and/or %APPDATA%/notepad++/plugins/config/ directory
