    UDL: Suffix Mode
    54 Posts 8 Posters 25.8k Views 1 Watching
    • Eko palypseE Offline
      Eko palypse
      Do the following
      • copy the script
      • goto Plugins->Python Script->New Script
      • give it a meaningful name and press save button
      • paste the script into the newly ceated document
      • save it
      • open one of your BR! Source files
      • click on Plugins->Python Script->Scripts->NAME_OF_THE_NEWLY_CREATED_PYTHONSCRIPT
      If you want to know the details, let me know.
        Eko palypse
        btw, when it works like you want and want it to be available automatically
        on every npp startup we need to create a USER startup.py but
        I guess this can be discussed it the script is useful to you at all
        • Michael Miller31M Offline
          Michael Miller31
          Thanks for putting the time into this!
          First, will this work on 64 bit N++?
          I had some trouble finding a version of Python Script that was compatible but I managed to find a beta version.
          also, I’m getting this error.
          File “C:\Users\mmiller\AppData\Roaming\Notepad++\plugins\Config\PythonScript\scripts\create_strings.py”, line 4, in <module>
          import ctypes
          File “C:\Program Files\Notepad++\plugins\PythonScript\lib\ctypes_init_.py”, line 7, in <module>
          from _ctypes import Union, Structure, Array
          ImportError: No module named _ctypes
          Eko palypseE 1 Reply Last reply Reply Quote 1
            Eko palypse @Michael Miller31
            Yes, as I’m using x64 version as well.
            Where did you download pythonscript plugin from?
            Why didn’t you use Plugin Manager?
            The official release channel for python script plugin is here.
              Michael Miller31
              I don’t have plugin manager so I went through http://docs.notepad-plus-plus.org/index.php?title=Plugin_Central .
              Thanks for dealing with my idiocy. Going through plugin manager worked perfectly. Is there any way I can donate for your time?
              Meta ChuhM 1 Reply Last reply Reply Quote 4
              • Meta ChuhM Offline
                Meta Chuh moderator @Michael Miller31
                @Michael-Miller31
                yes, we urgently need 5 macbook pro’s. 👍
                thanks in advance. 😂
                  Eko palypse
                  Thank you very much for asking and yes there is one thing
                  you could do if you like :-)
                  It might sound strange but if you have or know a cooking recipe
                  which is worth testing - I would appreciate.
                  I know tastes are different so … :-)
                    Eko palypse @Meta Chuh
                    @Meta-Chuh
                    REALLY - macbooks … NOWADAYS … :-D
                      Michael Miller31
                      I will get you a recipe when I get home from work. :-)
                      The macbooks will take some time. :-D
                      Eko palypseE 1 Reply Last reply Reply Quote 2
                        Michael Miller31
                        https://imgur.com/a/GWRaqec @Eko-palypse here’s my favorite recipe for muffins. :-D
                        Thanks again for your help.
                        I also realized afterwards that there are a few internal functions that end with $ and don’t start with fn but I just modified the regex to take care of them.
                        Eko palypseE Alan KilbornA 2 Replies Last reply Reply Quote 4
                          @Michael-Miller31
                          thank you thank you very much - very much appreciated - I LOVE MUFFINS (who doesn’t ?)
                          And also nice to see that you already made the script do what you want.
                          Have a nice day.
                          • Alan KilbornA Online
                            Alan Kilborn @Michael Miller31
                            @Michael-Miller31
                            Much better to have an actual recipe than simply all the talk of “baking cookies” that goes on around here sometimes!
                              Eko palypse
                              Help, I need somebody help I need somebody heeeelllppp :-D
                                Meta Chuh moderator @Eko palypse
                                @Eko-palypse
                                yesterday … all my troubles seemed so far away :-D
                                  I see the Beatles song lyrics references, but I’m unsure why Eko started it??
                                    @Michael-Miller31
                                    I found a little bug in the script.
                                    The area which needs to be styled is wrongly calculated if there are folded parts within this area.
                                    Please replace, within the style function, this line
                                    end_line = start_line + editor.linesOnScreen()
                                    with that line
                                    end_line = editor.docLineFromVisible(start_line + editor.linesOnScreen())
                                      Eko palypse @Alan Kilborn
                                      because this was the first thing which came into my mind after reading your comment about Scott-Sumner’s baking cookie comments :-D
                                        Hello, @michael-miller31, @eko-palypse, @alan-kilborn, @meta-chuh and All,
                                        Eko, I’ve just tried your python script and it works fine :-))
                                        I was a bit intrigued by your regex and I wanted to test other syntaxes. But after a while, I understood that your just take care of group 1 and dismiss the solution fn[A-Za-z0-9_]+?\$ Don’t you ?
                                        I tested this other solution (\b(?!fn)\w+\$), with success ! Of course, we could get rid of the group 1 but I suppose that your script should be slightly modified !
                                        Secondly, I tried to build, from the michael’s picture and text, an equivalent UDL, what I named… EKO and after some tests I was surprised because, although I just missed to update the UDL name, in your script, as below :
                                                    self.lexer_name = 'User Defined language file - EKO'
                                        Seemingly, it does not care about it ?! ( Just a comment : my BR Basic test file has no extension and I didn’t associate the EKO UDL to a specific extension )
                                        Eko palypseE 1 Reply Last reply Reply Quote 3
                                          Eko palypse @guy038
                                          @guy038
                                          thanks for testing and sharing an alternative regex.
                                          Concerning the script, if you just run the script it will flag the current
                                          document being of interest.
                                          If you would open multiple UDL documents and switch between them,
                                          then you should see that those documents work only if the UDL name
                                          is the one configured in the script.
                                          • Alexander SeidelA Offline
                                            Alexander Seidel
                                            Thanks for this great piece of code, Eko, I had a very similar problem, and simply changed the symbol and the color in the relevant line to fit my case.
                                            I was just wondering if you could help me with two additions, if it isn’t too much work to integrate:
                                            1. I have some cases where I don’t just want to change the color of the text, but also change the text from italic to non italic:
                                              int( —> int(
                                              Is this possible?
                                            2. In an ideal case, I would like comment lines to be excluded from this. In my case every line that start with, or contains # would have to be ignored by the python script.
                                            Thanks in advance, and have a nice day :)
                                            EkopalypseE 2 Replies Last reply Reply Quote 0
