    v7.6.3 auto completion *.cpp Not Working
    6 Posts 3 Posters 1.8k Views 1 Watching
    • 林園林 Offline
      林園
      Many words Not Working ,for example “accumulate,define,pragma”
      please help!!!
      • Meta ChuhM Offline
        Meta Chuh moderator @林園
        @林園
        keywords with a #prefix will not autocomplete automatically.
        if you want them to autocomplete after typing the prefix #you will have to add them without prefix to your cpp.xml.
        cpp.xml is usually located at:
        %ProgramFiles(x86)%\Notepad++\autoCompletion\cpp.xml for notepad++ x86,
        and %ProgramFiles%\Notepad++\autoCompletion\cpp.xml for notepad++ x64,
        or npp.7.6.3.bin[.x64]\autoCompletion\cpp.xml for portable versions.
        edit your cpp.xml and insert the following between <KeyWord name="#undef" /> and <KeyWord name="abort" func="yes">:
        		<KeyWord name="define" />
        		<KeyWord name="elif" />
        		<KeyWord name="else" />
        		<KeyWord name="endif" />
        		<KeyWord name="error" />
        		<KeyWord name="if" />
        		<KeyWord name="ifdef" />
        		<KeyWord name="ifndef" />
        		<KeyWord name="include" />
        		<KeyWord name="line" />
        		<KeyWord name="pragma" />
        		<KeyWord name="undef" />
        note: keys like accumulate should auto complete correctly on 7.6.3, if you have auto completion enabled.
        if not, here’s the current >>> cpp.xml <<< for you to use and/or compare.
        also make sure your cpp.xml is not in a folder called plugins/APIs, as this would be a wrong location, and only a left-over folder from an older notepad++ installation on your machine.
        • 林園林 Offline
          林園
          My cpp.xml is the same as yours. It should not be #prefix proleme.
            @林園
            if your cpp.xml is the same as mine, and you have added the lines as described above, your auto completion will work correctly, as seen at the screenshots below.
            if not, please re-check all instructions from above.
            Imgur
            Imgur
              Hello @林園, @meta-chuh and All,
              An other possibility which does not need any change in auto-completion files, is to modify the following N++ setting :
              Settings > Preferences... > Delimiters > Add your character as part of word in the Word character list zone
              Just insert a # character in the fied
              From now on, the # character is seen as a word character when double-clicking for selection and also, when searching in Normal mode search, with the option Match whole word only set !
              Just play around with that text, below, double clicking and searching, in Normal mode, with the Match whole word only checked or unchecked
               1 word #word word     5 word word# word      9 word wo#rd word
               2 word#word word      6 wordword# word      10 wordwo#rd word
               3 word #wordword      7 word word#word      11 word wo#rdword
               4 word#wordword       8 wordword#word       12 wordwo#rdword
              Remark :
              Note that, in that case, when using the Regular expression search mode, this added # character is still not considered as a word character ( \w ) and only as a NON-word character ( \W ) or as a punctuation character ( [[:punct:]] ) !
                Meta Chuh moderator @guy038
                @guy038
                very nice.
                your recommendation is the best way, as adding # as part of word, will also trigger auto completion immediately, as soon as a # is typed. 👍
