    Upgrading Scintilla, need help for boost
    5 Posts 3 Posters 1.3k Views 2 Watching
      I’m working on upgrading Scintilla to 4.14.
      And I’m trying to integrate the PCRE of last version of boost:
      https://www.boost.org/users/history/version_1_70_0.html
      For the moment, I managed to use bjam to build regex in debug dynamical binary.
      However I need to build a multi-thread static release library.
      Can anyone tell me how to build in with bjam under C:\boost_1_70_0\bin.v2\libs\regex\build ?
      EkopalypseE 1 Reply Last reply Reply Quote 5
        Ekopalypse @donho
        @donho
        If this is still an open point for you and I’m not sure if this info does help you but,
        what about cloning getboost repository and follow the guide how to build boost.
        Within boost.bat you can comment the unneeded compilers.
        It took around 6 minutes on my machine to build the various regex libraries.
        Note, this compiled only the boost::regex, none of the others.
        Command I used (within boost.bat it is the line before the last line) was
        b2 architecture=x86 link=%2 runtime-link=%3 threading=%4 address-model=%5 stage --stagedir=address-model-%5 --toolset=msvc-%1 --with-regex
        • MAPJe71M Offline
          MAPJe71
          See Boost C++ Libraries - Invocation for additional properties and the values allowed for the properties.
          FYI: Boost encourages to use the name b2 instead of bjam
          e.g.
          "%BOOSTPATH%\b2\bin\b2.exe" "toolset=msvc-14.1" "variant=debug,release" "threading=multi" "link=static" "runtime-link=static" "address-model=64"
          • MAPJe71M Offline
            MAPJe71
            Link no longer valid, try: Build Binaries from Source.
            • MAPJe71M Offline
              MAPJe71
              and see: Library Naming
