    A problem in Notepad++
    2 Posts 2 Posters 820 Views 1 Watching
    • Ramin ParsaR Offline
      Ramin Parsa
      Hi
      I open four tab in Notepad++ and use ctrl+alt+R. In all tabs, the text goes to the right while I used it for just a tab.
      • Meta ChuhM Offline
        Meta Chuh moderator @Ramin Parsa
        welcome to the notepad++ community, @Ramin-Parsa
        this is the default behaviour and has always been that way.
        when you switch from ltr to rtl, notepad++ will switch to right to left text editing for all tabs.
        best regards.
