    BUG: Problem with syntax highlighting: Not working on ASP Classic Scripts
    asphighlighthighlightingbug
    17 Posts 13 Posters 6.8k Views 4 Watching
    • DirtyEchoD Offline
      DirtyEcho
      From the last update (Notepad 7.7), It doesn’t highlight my code anymore.
      I try to set up styles and preference from the relative menu (Settings --> Style Configurator), but with no result.
      Someone could help me?
      • dailD Offline
        dail
        Most people here dont use ASP. It would be extremely helpful to post code snippets and screenshots.
        DirtyEchoD 1 Reply Last reply Reply Quote 2
          SalviaSage
          What file extension is that?
          Can you also give me some sample code so I can test it from my end?
          Thanks.
          DirtyEchoD 1 Reply Last reply Reply Quote 0
            DirtyEcho @dail
            @dail This is an example of an ASP Script:
            Session(“display”) = “Regitrazione”
            Session(“link”) = “register.asp”
            Normally in Notepad++ (until the 7.6.6 release) the content inside the ASP tags (“<% … %>”) was highlighted in light blue, also the ASP tags themseves were higlighted in yellow.
            This was until the 7.7 release, that contains a bug that don’t highligh the content in light blue.
            This is not a big problem, but I just want to know why, if It’s a chose made by the developers, or if It’s just an annoying bug.
              DirtyEcho @SalviaSage
              @SalviaSage The file extension is ASP (You can find it in Notepad++: Language --> ASP).
              Just copy/paste into a Notepad++ ASP set page.
                Ekopalypse @DirtyEcho
                @DirtyEcho
                I haven’t found any builtin theme which had set it to light blue but anyways, check if the color is set for your theme. To do so,
                goto Settings->Style Configurator->Language(choose ASP) and in Style choose ASPSYBOL. Now you can see and modify the color.
                  DirtyEcho @Ekopalypse
                  @Ekopalypse
                  Trying to explain me better i link this image: ASP Tags - Notepad++ 7.7.
                  The color “yellow” works good, If I change It into the “ASPSYBOL” section It’s displayed correctly; but the content inside the ASP tags should be highlighted in light blue (This image, took by using the previous version of Notepad++, explain me better for sure).
                  Any ideas?
                    @DirtyEcho
                    asp is no longer the default language for html lexer and has been changed to JS.
                    I guess this makes sense, doesn’t it?
                    But this means that the attribute asp.default.language needs to be set to 2 if one chooses ASP lexer.
                    You might open an issue here.
                    If by any chance you are using a scripting language plugin you can set it your self by doing something like editor.setProperty('asp.default.language', 2)
                    • Liga TablasL Offline
                      Liga Tablas
                      I have same problem. I changed the Lenguaje to ActionScript in the Notepad ++ (in Lenguaje–>A–>ActionScript option menú) and this changed colours. I now this is not solution, but I can see my code in colours, is better than see all in white and black
                      • Jacqui KingJ Offline
                        Jacqui King
                        I am having the same problem with ASP files. The reality is that there are still many sites running on classic ASP (whether it is fashionable or not). The colour coding worked until I upgraded to 7.7 today, and I have confirmed that it is still working on 7.5.9. Irrespective of the file extension (which is ASP in this case), I should be able to choose the language color-coding from the language menu. If I look at the Style Configurator, asp is still defined correctly, but it is only seeing the <%%> markers and nothing else. Something broke in the upgrade.
                        • Christian GuillodC Offline
                          Christian Guillod
                          I have the same problem and I have found that the colour coding still work if you have this line in the beginning of the file:
                          <%@LANGUAGE=“VBSCRIPT”%>
                            @dail has provided the fix here : https://github.com/notepad-plus-plus/notepad-plus-plus/pull/5708
                            The fix will be included in v7.7.1.
                            • Sriram NS Offline
                              Sriram N
                              Good to see that it’s getting fixed, this will help me. I had this problem too - it would recognize the <% %> code blocks, but would not highlight the language within them (VBScript) correctly unless if the <%@LANGUAGE=“VBSCRIPT”%> line was included.
                              • Nathaniel CourtensN Offline
                                Nathaniel Courtens
                                is anyone using UDL http://docs.notepad-plus-plus.org/index.php/User_Defined_Languages as alternative (for now)? And would they mind sharing their .xml?
                                • P Offline
                                  patrickdrd
                                  I don’t know if it’s been reported but I renamed a file and syntax highlighting was gone
                                  • kkmuffmeK Offline
                                    kkmuffme
                                    Same exact problem in PHP. NP++ ver 7.6.2 works correctly
                                    See: https://notepad-plus-plus.org/community/topic/17774/php-syntax-not-highliting-when-inside-other-language-string-ver-7-7
                                    • N Offline
                                      niente0
                                      Same here, my ASP scripts aren’t highlighted anymore since v7.7.
                                      I can confirm it works with Notepad++ 7.6.6, I downgraded until bug is fixed.
