    Style token not saved
    30 Posts 8 Posters 26.2k Views 4 Watching
    • BallardiniFANSB Offline
      BallardiniFANS @Alan Kilborn
      There is an error when I choose YES or NO:
        BallardiniFANS
        Now it works fine!!!
        Running Notepad as administrator the issue is fixed.
        Thank you very much @Alan-Kilborn
          Alan Kilborn @BallardiniFANS
          @BallardiniFANS
          OK, with the more detailed error reporting I can see what failed with the script. While running as administrator solves the problem, it is rather like cutting off your arm because you have a hangnail – problem solved, but…
          Note that I believe the intent of the script was just to demo the functionality, not really be useful in a general sense. Why do I say this? Because a single file is used for the data, it is only useful with a single source file. (There are some other logistical problems with saving and restoring styling, as well).
          Let me rework the script a little, I’ll post a new one here; check back here in a few days…
            It appears I didn’t give the original script a name in this thread, although I called it StylingSaveOrLoad.py on my setup. Thus, for a new script, I’ll call it StylingSaveOrLoad2.py.
            The new script is similar to the old, but a major way it is different is that it saves a .sty file in the same folder as the original file, to hold the styling data. Thus, if you’re editing test.txt and then save the styling by running the script, you’ll see test.sty in the same folder.
            Basic instructions on PythonScripting may be found HERE.
            Here’s the script listing:
            # -*- coding: utf-8 -*-
            # references:
            #  https://community.notepad-plus-plus.org/topic/18134/style-token-not-saved/
            from Npp import *
            import inspect
            import os
            class SSOL2(object):
                def __init__(self):
                    self.debug = True if 0 else False
                    if self.debug:
                        pass
                        #console.show()
                        #console.clear()
                    self.this_script_name = inspect.getframeinfo(inspect.currentframe()).filename.split(os.sep)[-1].rsplit('.', 1)[0]
                    # identifiers pulled from N++ source code:
                    SCE_UNIVERSAL_FOUND_STYLE_EXT1 = 25  # N++ style 1 indicator number
                    SCE_UNIVERSAL_FOUND_STYLE_EXT2 = 24  # N++ style 2 indicator number
                    SCE_UNIVERSAL_FOUND_STYLE_EXT3 = 23  # N++ style 3 indicator number
                    SCE_UNIVERSAL_FOUND_STYLE_EXT4 = 22  # N++ style 4 indicator number
                    SCE_UNIVERSAL_FOUND_STYLE_EXT5 = 21  # N++ style 5 indicator number
                    SCE_UNIVERSAL_FOUND_STYLE      = 31  # N++ red-"mark" feature highlighting style indicator number
                    self.indicator_number_list = [
                        SCE_UNIVERSAL_FOUND_STYLE_EXT1,
                        SCE_UNIVERSAL_FOUND_STYLE_EXT2,
                        SCE_UNIVERSAL_FOUND_STYLE_EXT3,
                        SCE_UNIVERSAL_FOUND_STYLE_EXT4,
                        SCE_UNIVERSAL_FOUND_STYLE_EXT5,
                        SCE_UNIVERSAL_FOUND_STYLE,
                def get_data_file_path_for_active_tab(self):
                    active_file_pathname = notepad.getCurrentFilename()
                    if not os.path.isfile(active_file_pathname): return None
                    if active_file_pathname.endswith('.sty'): return None
                    data_file_for_active_tab = active_file_pathname.rsplit('.', 1)[0] + '.sty'
                    return data_file_for_active_tab
                def save_data_file(self):
                    data_file_for_active_tab = self.get_data_file_path_for_active_tab()
                    if data_file_for_active_tab == None:
                        self.mb('Problem saving styling data for active tab file')
                        return
                    with open(data_file_for_active_tab, 'w') as fo:
                        for indic_number in self.indicator_number_list:
                            for (styled_start_pos, styled_end_pos) in self.highlight_indicator_range_tups_generator(indic_number):
                                fo.write('{i} {start} {stop}\n'.format(i=indic_number, start=styled_start_pos, stop=styled_end_pos))
                def load_data_file(self):
                    if data_file_for_active_tab == None or not os.path.isfile(data_file_for_active_tab):
                        self.mb('Problem loading styling data for active tab file')
                        return
                    with open(data_file_for_active_tab) as fi:
                        for line in fi:
                            (indic, start, end) = line.rstrip().split()
                            editor.setIndicatorCurrent(int(indic))
                            editor.indicatorFillRange(int(start), int(end) - int(start))
                def run(self):
                    saving_not_loading = self.yes_no_cancel('\r\n'.join([
                        "SAVE current doc's styling to disk file?\r\n",
                        "YES = Yes, please SAVE it",
                        "NO = LOAD styling info from file and apply to current doc",
                        "CANCEL = I'm outta here"]))
                    if saving_not_loading == None: return
                    self.save_data_file() if saving_not_loading else self.load_data_file()
                def highlight_indicator_range_tups_generator(self, indicator_number):
                    the following logic depends upon behavior that isn't exactly documented;
                    it was noticed that calling editor.indicatorEnd() will yield the "edge"
                    (either leading or trailing) of the specified indicator greater than the position
                    specified by the caller
                    this is definitely different than the scintilla documentation:
                    "Find the start or end of a range with one value from a position within the range"
                    if editor.indicatorEnd(indicator_number, 0) == 0: return
                    indicator_end_pos = 0  # set special value to key a check the first time thru the while loop
                    while True:
                        if indicator_end_pos == 0 and editor.indicatorValueAt(indicator_number, 0) == 1:
                            # we have an indicator starting at position 0!
                            # when an indicator highlight starts at position 0, editor.indicatorEnd()
                            #  gives us the END of the marking rather than the beginning;
                            #  have to compensate for that:
                            indicator_start_pos = 0
                        else:
                            indicator_start_pos = editor.indicatorEnd(indicator_number, indicator_end_pos)
                        indicator_end_pos = editor.indicatorEnd(indicator_number, indicator_start_pos)
                        if indicator_start_pos == indicator_end_pos: break  # no more matches
                        yield (indicator_start_pos, indicator_end_pos)
                def print(self, *args):
                    if self.debug:
                        print(self.__class__.__name__ + ':', *args)
                def mb(self, msg, flags=0, title=''):  # a message-box function
                    return notepad.messageBox(msg, title if title else self.this_script_name, flags)
                def yes_no_cancel(self, question_text):
                    retval = None
                    answer = self.mb(question_text, MESSAGEBOXFLAGS.YESNOCANCEL, self.this_script_name)
                    if answer == MESSAGEBOXFLAGS.RESULTYES: retval = True
                    elif answer == MESSAGEBOXFLAGS.RESULTNO: retval = False
                    return retval
            if __name__ == '__main__':
                SSOL2().run()
            You can directly invoke this script, to get a prompt box much like the original script:
            Or, if you prefer, you can set two up new keycombo-invoked scripts, such that one directly saves the data file, and one applies the styling from the data file (i.e., loads it).
            If you like the two-keycombo approach, here’s how to set up the additional scripts needed for that:
            • Add these lines to (user) startup.py:
            import StylingSaveOrLoad2
            ssol2 = StylingSaveOrLoad2.SSOL2()
            • Create a new script file called StylingSaveForCurrentFile.py with content:
            ssol2.save_data_file()
            • Create a new script file called StylingLoadForCurrentFile.py with content:
            ssol2.load_data_file()
            • Bind the running of these two scripts to keycombos of your choosing
            Jane EyreJ nsk7evenN SalepS 3 Replies Last reply Reply Quote 4
            • Jane EyreJ Offline
              Jane Eyre @Alan Kilborn
              @Alan-Kilborn Works!!! I don’t use notepad++ to develop code, only to create content for my websites, and that helped me a lot, thank you very much.
              • nsk7evenN Offline
                nsk7even @Alan Kilborn
                @Alan-Kilborn thank you for this great script! I tried it and it works kind of.
                Interestingly I have to run the script multiple times to let it apply (load) all word highlightings for a style token.
                It seems to be arbitrary how much occurrences of the word that is to be styled are missing.
                Do you have an idea of the reason of this behaviour?
                • nsk7evenN nsk7even referenced this topic on
                  Alan Kilborn @nsk7even
                  @nsk7even said in Style token not saved:
                  I can see the same thing; currently I don’t know why it is happening. :-(
                  • SalepS Offline
                    Salep @Alan Kilborn
                    @Alan-Kilborn said in Style token not saved:
                    hi I followed your guide it works perfect thank u.
                    but I dont know how can bind keys to those scripts.
                    can u help me with that?
                    sorry for necro if it is not allowed
                      PeterJones @Salep
                      @Salep said in Style token not saved:
                      The “Basic instructions on PythonScripting may be found HERE” link from Alan’s 2022-Nov-19 post contains the instructions on how to bind keys to those scripts, in installation step 4, in the point starting with “To give it a keyboard shortcut”
                      SalepS 1 Reply Last reply Reply Quote 0
                      • SalepS Offline
                        Salep @PeterJones
                        @PeterJones thank u sir I got it
