    Multi editing using Notepad++
    Scheduled Pinned Locked Moved Blogs
    blogmacroediting
    4 Posts 4 Posters 2.5k Views 3 Watching
    • Prince PatniP Offline
      Prince Patni
      Read the full blog here :
      https://princepatni.com/blog/tech/coding-tricks-using-multi-editing-in-notepad-to-do-your-tasks-faster/
      • Alan KilbornA Online
        Alan Kilborn @Prince Patni
        @Prince-Patni
        The info on multi-editing, although not incorrect, for me is a bit “meh”. You still have to click each spot you want a new caret to appear; how hard is it to paste the desired text right after doing that and dispense with all of the “type it and watch it appear in n places” visual magic? More often than not, I already have the text in the clipboard…
        I have yet to see a great use for multi-editing as it is implemented in Notepad++. Maybe someone can convince me that it really is a great feature (by providing an example showing why).
          @Alan-Kilborn said:
          convince me … by providing an example
          Convince you? Likely not. But I occasionally use the feature when I have a if/elseif/elseif… block (or select block, or similar) where I want to add the same thing in similar places, but haven’t yet typed it the first time to get it into the clipboard.
          It’s not a killer/must-have feature for me (because I could very easily type it the once, then use copy/paste to replicate to the other locations), but after learning the feature existed, I do occasionally use it.
          • dinkumoilD Offline
            dinkumoil @Alan Kilborn
            You are right, the way multi-editing is implemented currently is not very useful - to much hassle to place the cursor at multiple locations and you could easily miss one location.
            But with the new Scintilla commands SCI_MULTIPLESELECTADDNEXT and SCI_MULTIPLESELECTADDEACH we got the missing features to enjoy the power of multi-editing. If you are sure you want to overtype all occurences of a certain string send SCI_MULTIPLESELECTADDEACH. If you know that the string only occurs in a few locations near by the cursor (e.g. an if..else...endif block) send SCI_MULTIPLESELECTADDNEXT multiple times. Of course a scripting plugin is needed to be able to send these commands to Scintilla.
            In this comment @dail posted some Lua code to emulate SCI_MULTIPLESELECTADDNEXT in Notepad++ versions prior to v7.7 (which introduced the Scintilla version necessary for the two commands mentioned above). I was able to modify it to create an emulator for SCI_MULTIPLESELECTADDEACH as well (maybe I found that code somewhere, too), here are the two functions:
            npp.AddShortcut("Selection Add Next", "", function()
              -- From SciTEBase.cxx
              local flags = SCFIND_WHOLEWORD -- can use 0
              editor:SetTargetRange(0, editor.TextLength)
              editor.SearchFlags = flags
              -- From Editor.cxx
              if editor.SelectionEmpty or not editor.MultipleSelection then
                local startWord = editor:WordStartPosition(editor.CurrentPos, true)
                local endWord   = editor:WordEndPosition(startWord, true)
                editor:SetSelection(startWord, endWord)
              else
                local i = editor.MainSelection
                local s = editor:textrange(editor.SelectionNStart[i], editor.SelectionNEnd[i])
                local searchRanges = {{editor.SelectionNEnd[i], editor.TargetEnd}, {editor.TargetStart, editor.SelectionNStart[i]}}
                for _, range in pairs(searchRanges) do
                  editor:SetTargetRange(range[1], range[2])
                  if editor:SearchInTarget(s) ~= -1 then
                    editor:AddSelection(editor.TargetStart, editor.TargetEnd)
                    -- To scroll main selection in sight
                    editor:ScrollRange(editor.TargetStart, editor.TargetEnd)
                    break
                  end
                end
              end
              -- To turn on Notepad++ multi select markers
              editor:LineScroll(0, 1)
              editor:LineScroll(0, -1)
            end)
            npp.AddShortcut("Selection Add All", "", function()
              local startWord = -1
              local endWord   = -1
              local s         = ""
              else
                startWord = editor.SelectionNStart[i]
                endWord   = editor.SelectionNEnd[i]
              end
              s = editor:textrange(startWord, endWord)
              while true do
                local itemFound    = false
                    itemFound = true
                    break
                  end
                end
                if editor.TargetStart == startWord and
                   editor.TargetEnd   == endWord   or
                   not itemFound                   then
                  break
                end
              end
            end)
