    notepad++ fonts display too small on UBUNTU 16.04 (200%
    5 Posts 3 Posters 5.1k Views 3 Watching
    • ortolljO Offline
      ortollj
      HI
      I can not use notepad ++ because the menu titles are too small, unreadable on my TV screen by HDMI with a 200% magnification so is the text I enter( the letters are too small). I’ve searched in preferences without success.
        Font size is defined in Settings > Style Configurator > Global Styles > Default Style. Most other styles should inherit that setting (not overwrite font size).
        Anything else (ultra-high resolution monitors, external 200% scaling , etc) are, as far as I know, handled by the OS, not by Notepad++ directly.
        • P Offline
          pnedev
          How do you run Notepad++ on UBUNTU ?
          If you are using Wine to do that type winecfg in the terminal, go to Graphics tab and change the Screen resolution DPI value to your liking.
          No need to change the font size from within Notepad++ in this case.
          • ortolljO Offline
            ortollj
            @pnedev
            no I do not use Wine.
            thank you now I can use notepad++, despite the menus fonts are still too small, but the few times i need to use the menu, it is enough that I approach my screen TV.
            • P Offline
              pnedev
              @ortollj ,
              How do you run Notepad++ under Ubuntu then? By Snap?
