    How to create abbreviations for java code
    29 Posts 5 Posters 14.5k Views 1 Watching
      Hello, @michael-vincent, @peterjones and All,
      First, many thanks for building an x64 version of the QuickText plugin and for all the bug fixes
      May I bother you, a little bit, with a couple of weird things, still occurring in your last 0.1.2.4 version ?
      A) : First problem :
      • Let suppose that you place the caret right after a word, which is not a tag, for the current language
      • If you run the option Plugins > QuickText > Replace Tag, it writes :
        • The » character, in an ANSI encoded file ( An \xbb byte )
        • The value xBB, in reverse video, in any Unicode encoded text ( Indeed, this single byte is not valid in an Unicode file ! )
      This also happens if you run the Plugins > QuickText > Replace Tag option anywhere inside some blank range of text or even in an empty text. Is it the normal behaviour or is it a bug, due to my old Win XP SP3 laptop ?!
      B) Second problem :
      • Let’s suppose that the tags file QuickText.ini is opened, with other tabs, in your current N++ session
      • Then, you decide to delete the only tab ( copyright ) of the GLOBAL section, using the Plugins > QuickText > Options... option. After validating the suppression :
        • If the current tab is the QuickText.ini you must, first, switch to an other tab
      • Now, switch to the QuickText.ini tab to get the expected dialog : “This file has been modified by another program, do you want to reload it ?”
      • After a click on the Yes button of this dialog, you can notice that the layout of the sections of QuickText.ini has become completely different !
        • All the ini sections, which do not have any tag, have been deleted, including the [255] GLOBAL one, of course
        • From now on, the different sections are sorted alphabetically and NOT  numerically
      C) Third problem :
      • Let’s suppose that you change the TEXT section as below :
      [0]
      LANGUAGE_NAME=TXT
      LANGUAG_NAME=TXT_1
      LANGUAGES_NAME=TXT_2
      • After saving these changes, run the Plugins > QuickText > Refresh Configuration option
      • Then, paste the text, below, in a new text tab :
      aaaaa    LANGUAGE_NAME     zzzzz
      aaaaa    LANGUAG_NAME      zzzzz
      aaaaa    LANGUAGES_NAME    zzzzz
      • And run the option Plugins > QuickText > Replace Tag for each word in capitals
      We get :
      aaaaa    LANGUAGE_NAMExBB     zzzzz
      aaaaa    TXT_1      zzzzz
      aaaaa    TXT_2    zzzzz
      I would have expected that the LANGUAGE_NAME tag would have been expanded to the string TXT OR to the current language, for any language different of Normal Text
      BTW, why, in [0] section, the LANGUAGE_NAME is expanded to TXT whereas the language is TEXT ?
      D) To end with , a possible improvement :
      • It would be better to include all the other languages, with code over 49, giving the following default QuickText.ini file :
      [0]
      LANGUAGE_NAME=TXT
      [1]
      LANGUAGE_NAME=PHP
      for.sl=for (\$i = 0; \$i < $; ++\$i)\n	$
      for.ml=for (\$i = 0; \$i < $; ++\$i)\n{\n	$\n}
      foreach.sl=foreach (\$$ as \$k => \$v)\n	$
      foreach.ml=foreach (\$$ as \$k => \$v)\n{\n	$\n}
      function.public=public function $($)\n{\n	$\n}
      function.protected=protected function $($)\n{\n	$\n}
      function.private=private function $($)\n{\n	$\n}
      function.public.static=public static function $($)\n{\n	$\n}
      function.protected.static=protected static function $($)\n{\n	$\n}
      function.private.static=private static function $($)\n{\n	$\n}
      [2]
      LANGUAGE_NAME=C
      case=case $: $\n$
      def=#define $\n$
      default=default $: $\n$
      dowhile=do\n{\n	$\n}\nwhile ($);\n$
      dowhiles=do\n	$\nwhile ($);\n$
      else=else\n{\n	$\n}\n$
      elseif=else if ($)\n{\n	$\n}\n$
      elseifs=else if ($)\n	$\n$
      elses=else\n	$\n$
      for=for ($;$;$)\n{\n	$\n}\n$
      fors=for ($;$;$)\n	$\n$
      func=$ $($)\n{\n	$\n	return $;\n}\n$
      if=if ($)\n{\n	$\n}\n$
      ifelse=if ($)\n{\n	$\n}\nelse\n{\n	$\n}\n$
      ifelses=if ($)\n{\n	$\n}\nelse\n	$\n$
      ifs=if ($)\n	$\n$
      ifselse=if ($)\n	$\nelse\n{\n	$\n}\n$
      ifselses=if ($)\n	$\nelse\n	$\n$
      inc=#include <$>\n$
      incl=#include "$"\n$
      main=int main(int argc, char* argv[])\n{\n	$\n}\n
      switch=switch ($)\n{\n	$\n}\n$
      while=while ($)\n{\n	$\n}\n$
      whiles=while ($)\n	$\n$
      [3]
      LANGUAGE_NAME=CPP
      case=case $: $\n$
      class=class $ {\nprivate:\n	$\nprotected:\n	$\npublic:\n	$\n};\n$
      def=#define $\n$
      elses=else\n	$\n$
      hclass=#ifndef $\n#define $\n\nclass $ {\nprivate:\n	$\nprotected:\n	$\npublic:\n	$\n};\n\n#endif\n$
      ifs=if ($)\n	$\n$
      inc=#include <$>\n$
      [4]
      LANGUAGE_NAME=CS
      [5]
      LANGUAGE_NAME=OBJC
      [6]
      LANGUAGE_NAME=JAVA
      [7]
      LANGUAGE_NAME=RC
      [8]
      LANGUAGE_NAME=HTML
      a-id=<a id="$" href="$">$</a>
      b=<b>$</b>
      body=<body>\n	$\n</body>\n$
      body-id=<body id="$">\n	$\n</body>\n$
      br=<br />
      color.black=#000000
      color.blue=#0000FF
      color.cyan=#00FFFF
      color.green=#00FF00
      color.grey=#C0C0C0
      color.mangenta=#FF00FF
      color.white=#FFFFFF
      color.yellow=#FFFF00
      comment=<!-- $ -->\n$
      div-class=<div class="$">\n</div>
      div-id=<div id="$">\n</div>
      div-id-class=<div id="$" class="$">\n	$\n</div>
      div.p=<div class="p">\n	$\n</div>
      doctype.html.4.loose=<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"\n	"http://www.w3.org/TR/html4/loose.dtd">
      doctype.html.4.strict=<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"\n	"http://www.w3.org/TR/html4/strict.dtd">
      doctype.xhtml.1.0.loose=<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"\n	"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      doctype.xhtml.1.0.strict=<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"\n	"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
      doctype.xhtml.1.1=<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"\n	"http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
      fieldset=<fieldset class="$">\n	$\n</fieldset>
      form=<form name="$" action="$">\n	$\n</form>\n$
      h1=<h1>$</h1>
      h2=<h2>$</h2>
      h3=<h3>$</h3>
      h4=<h4>$</h4>
      h5=<h5>$</h5>
      h6=<h6>$</h6>
      head=<head>\n	$\n</head>\n$
      html-body=<html>\n<head>\n		<title>$</title>\n	$\n	</head>\n	<body>\n	$\n	</body>\n</html>
      i=<i>$</i>$
      img=<img src="$" alt="$" />\n$
      input=<input type="$" name="$" />\n$
      li=<li>$</li>
      lil=<li>\n	$\n</li>
      link=<a href="$">$</a>$
      ol=<ol>\n	<li>$</li>\n</ol>
      p=<p>\n	$\n</p>
      pre=<pre>$</pre>\n$
      pre-class=<pre class="$">\n	$\n</pre>
      prel=<pre>\n	$\n</pre>
      span=<span>$</span>
      table-id=<table id="$">\n	<tr>\n		<td id="$">\n			$\n		</td>\n	</tr>\n</table>
      td=\n<td>\n	$\n</td>
      title=<title>$</title>\n$
      tr=\n<tr>\n	$\n</tr>
      ul=<ul>\n	<li>$</li>\n</ul>
      url=http://
      www=http://www.
      [9]
      LANGUAGE_NAME=XML
      [10]
      LANGUAGE_NAME=MAKEFILE
      [11]
      LANGUAGE_NAME=PASCAL
      [12]
      LANGUAGE_NAME=BATCH
      [13]
      LANGUAGE_NAME=INI
      [14]
      LANGUAGE_NAME=NFO
      [15]
      LANGUAGE_NAME=USER
      [16]
      LANGUAGE_NAME=ASP
      [17]
      LANGUAGE_NAME=SQL
      [18]
      LANGUAGE_NAME=VB
      [19]
      LANGUAGE_NAME=JS
      for.sl=for (var i = 0; i < $; ++i)\n	$
      for.ml=for (var i = 0; i < $; ++i)\n{\n	$\n}
      foreach.sl=for (var x in $)\n	$
      foreach.ml=for (var x in $)\n{\n	$\n}
      [20]
      LANGUAGE_NAME=CSS
      [21]
      LANGUAGE_NAME=PERL
      Dumper=use Data::Dumper; \$Data::Dumper::Sortkeys=1; print Dumper \ $; exit;$
      csv=my \$csv = Text::CSV->new( {sep_char => ',', binary => 1} )\n  or die Text::CSV->error_diag;\n\nopen my \$fh, '<', \$$\n  or die "\$!";\n\nwhile ( my \$row = \$csv->getline(\$fh) ) {\n    $\n}\nif ( not \$csv->eof ) {\n    my ( \$cde, \$str, \$pos ) = \$csv->error_diag;\n}\n$
      else=else {\n    $\n}\n$
      elsif=if ( $ ) {\n    $\n} elsif ( $ ) {\n    $\n} else {\n    $\n}\n$
      for=for my \$$ ( $ ) {\n    $\n}\n$
      if=if ( $ ) {\n    $\n}\n$
      ifelse=if ( $ ) {\n    $\n} else {\n    $\n}\n$
      mlread=my \$START = '$';\nmy \$STOP  = '$';\nmy \$INCLUDE_START = $1;\nmy \$INCLUDE_STOP  = $1;\nmy @data;\nfor ( $ ) {\n    if ( /\$START/ .. /\$STOP/ ) {\n        next if ( not \$INCLUDE_START and /\$START/ );\n        push @data, \$_ unless ( not \$INCLUDE_STOP and /\$STOP/ );\n        process_data() if ( /\$STOP/ );\n        next;\n    }\n    process_nodata();\n}\nprocess_data\n\nsub process_data {\n    return if not @data;\n    # operate on @data\n    $\n    @data = ();\n}\n\nsub process_nodata {\n    # operate on \$_\n    $\n}\n$
      open=open my \$fh, '<', \$$;\nmy @lines = <\$fh>;\nclose \$fh;\n$
      package=package $;\nuse Class::Struct;\nstruct( $ => '\$', $ => '@', $ => '$Module::Name' );\n1;\n$
      sopen=my \$lines;\n{\n    local \$/ = undef;\n    open my \$fh, '<', \$$;\n    \$lines = <\$fh>;\n    close \$fh;\n}\n$
      start=#!perl\n\nuse strict;\nuse warnings;\n\n$
      sub=sub $ {\n    my (\$$) = @_;\n\n    $\n}\n$
      wantarray=my @rets;\nmy \$retType = wantarray;\n\nif ( not defined \$retType ) {\n    print "$@rets";\n} elsif (\$retType) {\n    return @rets;\n} else {\n    return \@rets;\n}\n$
      while=while ( $ ) {\n    $\n}\n$
      [22]
      LANGUAGE_NAME=PYTHON
      [23]
      LANGUAGE_NAME=LUA
      [24]
      LANGUAGE_NAME=TEX
      [25]
      LANGUAGE_NAME=FORTRAN
      [26]
      LANGUAGE_NAME=BASH
      [27]
      LANGUAGE_NAME=FLASH
      [28]
      LANGUAGE_NAME=NSIS
      [29]
      LANGUAGE_NAME=TCL
      else=} else {\n $
      foreach=foreach $ $ {\n $\n}\n$
      if=if { $ } {\n $\n}\n$
      ifelse=if { $ }\n $\n} else {\n $\n}
      proc=# $\nproc $ { $ } {\n $\n}\n$
      regsub=regsub -all {$} "$" {$} $\n$
      [30]
      LANGUAGE_NAME=LISP
      [31]
      LANGUAGE_NAME=SCHEME
      [32]
      LANGUAGE_NAME=ASM
      [33]
      LANGUAGE_NAME=DIFF
      [34]
      LANGUAGE_NAME=PROPS
      [35]
      LANGUAGE_NAME=PS
      [36]
      LANGUAGE_NAME=RUBY
      [37]
      LANGUAGE_NAME=SMALLTALK
      [38]
      LANGUAGE_NAME=VHDL
      Ris=Rising_Edge ( $ )$
      access=type $ is access $;\n$
      alias=alias $ is $;\n$
      archi=architecture $ of $ is\n$\nbegin\n$\nend $;\n$
      array=type $ is\n array ( $ ) of $;\n$
      assert=assert ( $ )\n report "$"\n sevrity $;\n$
      block=$ : block $\nbegin\n $\nend block $;\n$
      case=case $ is\n when $ =>\n $;\n when others =>\n $;\nend case;\n$
      com=--\n-- $\n--
      component=component $\n port (\n $\n );\nend component $;\n$
      config=for $ : $\n use $\n $;\n$
      constant=constant $: $;\n$
      elsif=elsif ( $ ) then\n $;
      entity=entity $ is\n port (\n $\n );\nend $;\n$
      enum=type $ is ( $, $ );
      exit=exit $ when $;\n$
      file=file $ : $ is $;\n$
      for=$ : for $ in $ downto $ loop\n $;\nend loop $;\n$
      function=function (\n $\n )return $ is\n $\nbegin\n $\nend $;
      functiond=function $ (\n $\n) return $;\n$
      geneif=$ : if ( $ = $ ) generate\n $\nbegin\n $\nend generate $;
      generate=$ : for $ in $ downto $ generate\n $\nbegin\n $\nend generate $;\n$
      generic=generic (\n $\n );\n$
      genmap=generic map (\n $\n)\n$
      group=group $ is ( $ );\n$
      ieee=library ieee;\n use ieee.std_logic_1164.all;\n $
      if=if ( $ ) then\n $;\n$end if;\n$
      ifelse=if ( $ ) then\n $\nelse\n $\nend if;\n$
      ifelsif=if ( $ ) then\n $\nelsif ( $ )\n $\nend if;\n$
      loop=$ : loop\n $\nend loop;\n$
      map=$ : $\n port map (\n $\n );\n$
      mapgen=$ : $\n generic map (\n $\n )\n port map (\n $\n );\n$
      next=$ : next $ when $;\n$
      numeric=use ieee.numeric_std.all;\n$
      pack=package $ is\n $\nend package $;\n\npackage body $ is\n $\nend package body $;\n$
      port=port (\n $\n );\n$
      procedure=procedure $ (\n $\n ) is\n$\nbegin\n $\nend procedure $;\n$
      procedured=procedure $ (\n $\n);\n$
      process=$ : process ( $ )\nbegin\n $\nend process $;\n$
      proclk=$ : process ( $, $ )\n begin\n if ( $ = '$' ) then\n $ <= $;\n elsif( Rising_Edge( $ ) ) then\n $\n end if;\nend process $;
      protected=protected\n $\nend protected ;
      record=type $ is\n record\n $ : $ ;\nend record $;\n$
      start=library ieee;\n use ieee.std_logic_1164.all;\n\nentity $ is\n port (\n $\n );\nend $;\n\narchitecture $ of $ is\n$\nbegin\n$\nend $;\n$
      std=signal $ : std_logic$;\n$
      stdpi=$ : in std_logic;\n$
      stdpio=$ : inout std_logic;\n$
      stdpo=$ : out std_logic;\n$
      stdtextio=use ieee.std_logic_textio.all;\n$
      stdv=signal $ : std_logic_vector( $ downto 0);\n$
      stdvar=variable $ : std_logic;\n$
      stdvpi=$ : in std_logic_vector( $ downto $);\n$
      stdvpio=$ : inout std_logic_vector( $ downto $);\n$
      stdvpo=$ : out std_logic_vector( $ downto $);\n$
      stdvvar=variable $ : std_logic_vector( $ downto 0);\n$
      subtype=subtype $ is $;\n$
      textio=use std.textio.all;\n$
      units=units\n $;\nend units;\n$
      waitf=wait for $;\n$
      waitu=wait until $;\n$
      waituf=wait until $ for $;\n$
      when=when $ =>\n $;$
      whene=when ( $ ) else $;
      while=$ : while $ loop\n $;\nend loop;\n$
      x=x"$"$
      [39]
      LANGUAGE_NAME=KIX
      [40]
      LANGUAGE_NAME=AU3
      [41]
      LANGUAGE_NAME=CAML
      [42]
      LANGUAGE_NAME=ADA
      [43]
      LANGUAGE_NAME=VERILOG
      [44]
      LANGUAGE_NAME=MATLAB
      [45]
      LANGUAGE_NAME=HASKELL
      [46]
      LANGUAGE_NAME=INNO
      [47]
      LANGUAGE_NAME=SEARCHRESULT
      [48]
      LANGUAGE_NAME=CMAKE
      [49]
      LANGUAGE_NAME=YAML
      [50]
      LANGUAGE_NAME=COBOL
      [51]
      LANGUAGE_NAME=GUI4CLI
      [52]
      LANGUAGE_NAME=D
      [53]
      LANGUAGE_NAME=POWERSHELL
      [54]
      LANGUAGE_NAME=R
      [55]
      LANGUAGE_NAME=JSP
      [56]
      LANGUAGE_NAME=COFFEESCRIPT
      [57]
      LANGUAGE_NAME=JSON
      [58]
      LANGUAGE_NAME=JAVASCRIPT
      [59]
      LANGUAGE_NAME=FORTRAN_77
      [60]
      LANGUAGE_NAME=BAANC
      [61]
      LANGUAGE_NAME=SREC
      [62]
      LANGUAGE_NAME=IHEX
      [63]
      LANGUAGE_NAME=TEHEX
      [64]
      LANGUAGE_NAME=SWIFT
      [65]
      LANGUAGE_NAME=ASN1
      [66]
      LANGUAGE_NAME=AVS
      [67]
      LANGUAGE_NAME=BLITZBASIC
      [68]
      LANGUAGE_NAME=PUREBASIC
      [69]
      LANGUAGE_NAME=FREEBASIC
      [70]
      LANGUAGE_NAME=CSOUND
      [71]
      LANGUAGE_NAME=ERLANG
      [72]
      LANGUAGE_NAME=ESCRIPT
      [73]
      LANGUAGE_NAME=FORTH
      [74]
      LANGUAGE_NAME=LATEX
      [75]
      LANGUAGE_NAME=MMIXAL
      [76]
      LANGUAGE_NAME=NIMROD
      [77]
      LANGUAGE_NAME=NNCRONTAB
      [78]
      LANGUAGE_NAME=OSCRIPT
      [79]
      LANGUAGE_NAME= REBOL
      [80]
      LANGUAGE_NAME=REGISTRY
      [81]
      LANGUAGE_NAME=RUST
      [82]
      LANGUAGE_NAME=SPICE
      [83]
      LANGUAGE_NAME=TXT2TAGS
      [84]
      LANGUAGE_NAME=VISUALPROLOG
      [85]
      LANGUAGE_NAME=EXTERNAL
      [255]
      LANGUAGE_NAME=GLOBAL
      copyright=Copyright (C) $ 20$\n\nhttp://$\n\nAll rights reserved\n$
      Thanks for taking the time to read this post through to the end ;-))
      • Michael VincentM Offline
        Michael Vincent @guy038
        @guy038
        A) This does not happen for me. It is probably as expected for now since I always use ANSI encoded files and my QuickText.ini is ANSI encoded. As @PeterJones documented in the GitHub issues, UNICODE does not work in this plugin and since there is a mess of someone else’s old code, I’m not prioritizing fixing that - sorry.
        B) The tab switching to get the change notification happens for me with any file in N++. Not sure that’s related. The order of sections is as expected as well since when the file is rewritten, it’s written according to looping through the C++ vector storing the languages - I don’t believe any sort is applied. So however they are in there, they are written out. I’ll see if there’s a way to easily sort, but I don’t think it’s necessary.
        C) LANGUAGE_NAME is not a tag. It’s a comment. The original version didn’t even check for it so if yo had them, they would show up as tags. I ignored them originally, but then they weren’t rewritten to the file on save so disappeared. Now I purposefully placed them back in, but they should never be visible in the Options dialog as Tags to expend. I’ll see if I can make that more clear by making them #LANGUAGE_NAME. So the behavior if replacing tags is as expected, the first one does not expand since it is not a valid tag (not seen in Options dialog) and you’re hitting the issue in A) about encoding. The second and third don’t match the regex I look to ignore for comments so show up as valid tags and are expanded.
        D) I think would be too difficult to implement as I’d need to track all languages with some placeholder in the vector even though they don’t have tags. And as in B), they certainly wouldn’t stay in order.
        Hope that helps explain some of the behavior. I’ll see about changing C) to make the comment more obvious but I don’t think the rest will be fixed anytime soon unfortunately. I just don’t have the skills or time for that kind of re-write.
        Cheers.
          Hi, @michael-vincent, @peterjones and All,
          Many thanks for your prompt reply :
          Regarding point A) :
          In fact , I don’t really mind about this QuickText.dll behaviour, when trying to run the Plugins > QuickText > Replace Tag option, with caret close to a word which is not a tag, for current language. But, out of curiosity, what happens when using the Replace Tag option, in your system ?
          BTW, as my settings for Setting > Preferences... > new Document > Encoding is UTF_8, with the Applied to opened ANSI files option ticked AND as the QuickText.ini file does not have any character with Unicode code-point over \x007F, the chosen encoding for the QuickText.ini file is always UTF_8, when starting N++ !
          Even if I force the QuickText.ini to have an ANSI encoding, I still get the xbb character, in reverse video, if current fie is Unicode encoded or the » character if current file is ANSI encoded !
          Regarding point B) :
          I just wanted to emphasize that, after suppression of the unique global tag copyright, in addition to all the changes of the QuickText.in file, which occurs, if the current N++ file is QuickText.ini file, then the update dialog does not appear. You’ll need to switch to any other tab and, then, switch back to the QuickText.ini to get this dialog !!
          Regarding point C) :
          Ah…OK, I understand ! And you’re right : probably the syntax #LANGUAGE_NAME would remove the ambiguity !
          Regarding point D
          Oh ! I was not asking for a dynamic and updated list of all N++ possible languages, at any time, but, only, for a static updated list of present languages, used in the v7.8.4 release !
            @guy038
            Thanks for the feedback. Let me try to explain further.
            A)
            When using either the menu option Plugins > QuickText > Replace Tag or the shortcut key I have mapped to that (which is Tab) anywhere in a document I just get a ‘tab’ inserted (which I have N++ converting into 4 spaces). The same goes for in proximity to a tag. If my caret is adjacent to the end of a tag word for the current doc type, then the hotkey or the menu option both perform as expected - expanding the tag without insertion of any weird characters.
            Note my default file type in N++ is ANSI and when I menu option Plugins > QuickText > Open Tags File, that opens as ANSI as well.
            I’m still thinking this is an ANSI / Unicode thing, but it could also be the shortcut key you have mapped to the menu option, unless just using the menu option directly still produces the weird character insertion. If that’s the case, I’m sticking with my ANSI / Unicode issue which @PeterJones describes in GitHub issues 14 and 15.
            B)
            I believe this is just default behavior of N++. Proof of concept: create 2 files:
            %TEMP%\deleteme.txt:
            this file will be deleted
            %TEMP%\deleteme.bat:
            @echo off
            REM this is a 7 second sleep
            ping -n 7 localhost > NUL
            del %TEMP%\deleteme.txt
            Open %TEMP%\deleteme.txt in N++. In a command prompt, run the deleteme.bat file and while it’s doing its 7 second sleep, click back to N++ and activate the tab with deleteme.txt. You’ll notice nothing happens. Even after the batch file completes and deletes the file you’re looking at, N++ does nothing. You’ll need to click a different tab and the click back to the deleteme.txt tab for N++ to prompt that the file has changed do you want to reload from disk.
            I see this as the same. You have QuickText.ini open. You make a change which rewrites it. Unless you somehow reactivate the tab with QuickText.ini in it (click off it than back on it) you won’t get the N++ reload from disk prompt.
            C)
            I made that change and pushed to GitHub. There is no precompiled release, you’ll need to compile yourself. Note there are other changes you may need to manually make like removing the hash “#” as an allowedChar from your plugins/config/QuickText.conf.ini file and manually adding the hash “#” in front of all the LANGUAGE_NAME= in your plugins/QuickText/QuickText.ini file. For new installs, you won’t need to do this, but if you already have an install, you probably need to. Sorry.
            D)
            Again, this is someone else’s code that I understand about 10% of and given my poor C++ skills, I don’t really know how to improve it (i.e., GitHub issues 14 and 15 mentioned above). The tags are read into memory and are not read on demand from the file. So when reading in the tags, if a language does not have a tag, there is no entry created in the C++ vector in memory. Now when it comes time to save the file, we use an “iterator” to go through the C++ vector in memory (which no longer has any of the languages that had no tags) and it goes in whatever order a C++ iterator does (I have no idea how to make it sort nicely). In fact, like I said previously, there was no place in the memory list to store the LANGUAGE_NAME so when the file was rewritten, all that was lost. I just added that back in as part of these latest fixes.
            You can see all this in the GitHub:
            https://github.com/vinsworldcom/nppQuickText/blob/develop/lib/INIMap.cpp
            Here we have the regex when reading the tags in to ignore the LANGUAGE_NAME - now with the hash “#” to make like a coment.
            Here we have the WriteFile() routine that saves the tags file. You’ll see I had to add the “lang_menu” argument as input so I could map to the language name by ID and get the #LANGUAGE_NAME= rewritten (which wasn’t there in the original code. Also you can see the for() loop base on an iterator. It’s iterating through a data structure with key/value pairs so not easy for me to just us a for() loop with index to loop through all languages and write them to file regardless of whether they have tags or not. It could be possible, but beyond my abilities.
            All this to say I was surprised to see that this is in the Plugins Admin - I probably never noticed since I already had it installed, it never showed as “available” for me. This isn’t “my” code, just my improvements to work for me which I’m happy to share, but purposely didn’t publish myself knowing there were shortcomings / bugs / etc. that when exposed to a wider audience, people would want fixed, but would be beyond my capabilities (i.e., time, skills, general code-base understanding).
            Hope that helps clarify things.
            Cheers.
              Thanks, again for all your explanations
              • Regarding point A
              I understood the problem. If I use the TAB key ( which has the SCI_TAB duplicate ) everything is OK !
              Before, I used the Ctrl + Alt + = shortcut for the Plugins > QuixckText > Replace Tag command, which, indeed, writes the single byte \xBB, whatever the file encoding
              After some searches, I found out that the QuickText plugin simply displays the character whose decimal value is the scan-code of the key, read by the Shortcut Mapper. Of course, for key codes over 127, the result is different between an ANSI and Unicode file !
              Here is, below, an almost exhaustive list, where :
              • Column 1 contains the name of keys, used with Shift and/or Ctrl and/or Alt, in the Shortcut Mapper
              • Column 2 contains the character displayed, in an Unicode file, by the QuickText plugin, when caret is not close to an abbreviation tag
              • Column 3 contains the character displayed, in an ANSI file, by the QuickText plugin, when caret is not close to an abbreviation tag
              • Column 4 contains the decimal N++ Scan-code of the key, read by the Shortcut Mapper
                  |     1     |   2   |  3  |  4  |
                  | Backspace |  BS   | BS  |  08 |
                  | Tab       |  TAB  | TAB |  09 |
                  | Enter     |  CR   | CR  |  13 |
                  | Esc       |  ESC  | ESC |  27 |
                  | Spacebar  |  SPC  | SPC |  32 |
                  | Page up   |  !    |  !  |  33 |
                  | Page down |  "    |  "  |  34 |
                  | End       |  #    |  #  |  35 |
                  | Home      |  $    |  $  |  36 |
                  | Left      |  %    |  %  |  37 |
                  | Up        |  &    |  &  |  38 |
                  | Right     |  '    |  '  |  39 |
                  | Down      |  (    |  (  |  40 |
                  | INS       |  -    |  -  |  45 |
                  | DEL       |  .    |  .  |  46 |
                  |    ;      |  xBA  |  º  | 186 |
                  |    =      |  xBB  |  »  | 187 |
                  |    ,      |  xBC  |  ¼  | 188 |
                  |    .      |  xBE  |  ¾  | 190 |
                  |    /      |  xBF  |  ¿  | 191 |
                  |    ~      |  xC0  |  À  | 192 |
                  |    [      |  xDB  |  Û  | 219 |
                  |    \      |  xDC  |  Ü  | 220 |
                  |    ]      |  xDD  |  Ý  | 221 |
                  |    '      |  xDE  |  Þ  | 222 |
                  |    <>     |  xE2  |  â  | 226 |
                  |    F1     |   p   |  p  | 112 |
                  |    F2     |   q   |  q  | 113 |
                  |    F11    |   z   |  z  | 122 |
                  |    F12    |   {   |  {  | 123 |
                  |    0      |   0   |  0  |  48 |
                  |    1      |   1   |  1  |  49 |
                  |    8      |   8   |  8  |  56 |
                  |    9      |   9   |  9  |  57 |
                  |    A      |   A   |  A  |  65 |
                  |    B      |   B   |  B  |  66 |
                  |    Y      |   Y   |  Y  |  89 |
                  |    Z      |   Z   |  Z  |  90 |
                  | Numpad 0  |   `   |  `  |  96 |
                  | Numpad 1  |   a   |  a  |  97 |
                  | Numpad 8  |   h   |  h  | 104 |
                  | Numpad 9  |   i   |  j  | 105 |
                  |   Num *   |   j   |  j  | 106 |
                  |   Num +   |   k   |  k  | 107 |
                  |   Num -   |   m   |  m  | 109 |
                  |   Num .   |   n   |  n  | 110 |
                  |   Num /   |   o   |  o  | 111 |
                  |     1     |   2   |  3  |  4  |
              • Regarding point B :
              Ah…, OK ! This behaviour is normal and is not related to the QuickText plugin at all ! BTW, thanks for your instructive example ;-))
              • Regarding point C :
              As you said :
              • I deleted the # symbol from the allowedChars variable, in the QuickText.conf.ini file
              • I changed any line LANGUAGE-NAME=.... with the comment # LANGUAGE-NAME=...., in the `QuickText.ini file
              Note that, in my configuration, these two .ini files are UTF-8 encoded !
              And it seems that every abbreviation tag is fully functional, when the corresponding language is selected ;-)) I just did few tests, in various languages, of course !
              Remark : I noticed that all the # LANGUAGE_NAME entries are considered as abbreviation tags, in the Plugins > QuickText > Options... dialog
              • Regarding point D
              As my C skills are quite near 0, I simply decided to give it a try. So, I just added all languages, with code from 50 ( COBOL ) to 84 ( Visual Prolog ) to the QuickText.ini file
              And, I was happily surprised to find that, after defining an abbreviation tag for these two new languages, in the QuickText.ini file, the hit of the ESC key correctly expanded them to their substitution text, just as expected, once the COBOL or Visual Prolog language was selected, for a standard UTF-8 encoded file :-))
              In the next post, you’ll find the exact contents of my QuickText.ini file, without few abbreviation tags used during my tests, of course !
                Hi, all,
                As promised, the contents of my customized QuickText.ini file :
                [0]
                # LANGUAGE_NAME=TXT
                [1]
                # LANGUAGE_NAME=PHP
                [2]
                # LANGUAGE_NAME=C
                case=case $: $\n$
                def=#define $\n$
                elses=else\n	$\n$
                ifs=if ($)\n	$\n$
                inc=#include <$>\n$
                [3]
                # LANGUAGE_NAME=CPP
                case=case $: $\n$
                def=#define $\n$
                elses=else\n	$\n$
                ifs=if ($)\n	$\n$
                inc=#include <$>\n$
                [4]
                # LANGUAGE_NAME=CS
                [5]
                # LANGUAGE_NAME=OBJC
                [6]
                # LANGUAGE_NAME=JAVA
                [7]
                # LANGUAGE_NAME=RC
                [8]
                # LANGUAGE_NAME=HTML
                b=<b>$</b>
                br=<br />
                color.black=#000000
                color.blue=#0000FF
                color.cyan=#00FFFF
                color.green=#00FF00
                color.grey=#C0C0C0
                color.white=#FFFFFF
                h1=<h1>$</h1>
                h2=<h2>$</h2>
                h3=<h3>$</h3>
                h4=<h4>$</h4>
                h5=<h5>$</h5>
                h6=<h6>$</h6>
                i=<i>$</i>$
                li=<li>$</li>
                lil=<li>\n	$\n</li>
                p=<p>\n	$\n</p>
                pre=<pre>$</pre>\n$
                span=<span>$</span>
                url=http://
                www=http://www.
                [9]
                # LANGUAGE_NAME=XML
                [10]
                # LANGUAGE_NAME=MAKEFILE
                [11]
                # LANGUAGE_NAME=PASCAL
                [12]
                # LANGUAGE_NAME=BATCH
                [13]
                # LANGUAGE_NAME=INI
                [14]
                # LANGUAGE_NAME=NFO
                [15]
                # LANGUAGE_NAME=USER
                [16]
                # LANGUAGE_NAME=ASP
                [17]
                # LANGUAGE_NAME=SQL
                [18]
                # LANGUAGE_NAME=VB
                [19]
                # LANGUAGE_NAME=JS
                [20]
                # LANGUAGE_NAME=CSS
                [21]
                # LANGUAGE_NAME=PERL
                [22]
                # LANGUAGE_NAME=PYTHON
                [23]
                # LANGUAGE_NAME=LUA
                [24]
                # LANGUAGE_NAME=TEX
                [25]
                # LANGUAGE_NAME=FORTRAN
                [26]
                # LANGUAGE_NAME=BASH
                [27]
                # LANGUAGE_NAME=FLASH
                [28]
                # LANGUAGE_NAME=NSIS
                [29]
                # LANGUAGE_NAME=TCL
                else=} else {\n $
                [30]
                # LANGUAGE_NAME=LISP
                [31]
                # LANGUAGE_NAME=SCHEME
                [32]
                # LANGUAGE_NAME=ASM
                [33]
                # LANGUAGE_NAME=DIFF
                [34]
                # LANGUAGE_NAME=PROPS
                [35]
                # LANGUAGE_NAME=PS
                [36]
                # LANGUAGE_NAME=RUBY
                [37]
                # LANGUAGE_NAME=SMALLTALK
                [38]
                # LANGUAGE_NAME=VHDL
                com=--\n-- $\n--
                x=x"$"$
                [39]
                # LANGUAGE_NAME=KIX
                [40]
                # LANGUAGE_NAME=AU3
                [41]
                # LANGUAGE_NAME=CAML
                [42]
                # LANGUAGE_NAME=ADA
                [43]
                # LANGUAGE_NAME=VERILOG
                [44]
                # LANGUAGE_NAME=MATLAB
                [45]
                # LANGUAGE_NAME=HASKELL
                [46]
                # LANGUAGE_NAME=INNO
                [47]
                # LANGUAGE_NAME=SEARCHRESULT
                [48]
                # LANGUAGE_NAME=CMAKE
                [49]
                # LANGUAGE_NAME=YAML
                [50]
                # LANGUAGE_NAME=COBOL
                [51]
                # LANGUAGE_NAME=GUI4CLI
                [52]
                # LANGUAGE_NAME=D
                [53]
                # LANGUAGE_NAME=POWERSHELL
                [54]
                # LANGUAGE_NAME=R
                [55]
                # LANGUAGE_NAME=JSP
                [56]
                # LANGUAGE_NAME=COFFEESCRIPT
                [57]
                # LANGUAGE_NAME=JSON
                [58]
                # LANGUAGE_NAME=JAVASCRIPT
                [59]
                # LANGUAGE_NAME=FORTRAN_77
                [60]
                # LANGUAGE_NAME=BAANC
                [61]
                # LANGUAGE_NAME=SREC
                [62]
                # LANGUAGE_NAME=IHEX
                [63]
                # LANGUAGE_NAME=TEHEX
                [64]
                # LANGUAGE_NAME=SWIFT
                [65]
                # LANGUAGE_NAME=ASN1
                [66]
                # LANGUAGE_NAME=AVS
                [67]
                # LANGUAGE_NAME=BLITZBASIC
                [68]
                # LANGUAGE_NAME=PUREBASIC
                [69]
                # LANGUAGE_NAME=FREEBASIC
                [70]
                # LANGUAGE_NAME=CSOUND
                [71]
                # LANGUAGE_NAME=ERLANG
                [72]
                # LANGUAGE_NAME=ESCRIPT
                [73]
                # LANGUAGE_NAME=FORTH
                [74]
                # LANGUAGE_NAME=LATEX
                [75]
                # LANGUAGE_NAME=MMIXAL
                [76]
                # LANGUAGE_NAME=NIMROD
                [77]
                # LANGUAGE_NAME=NNCRONTAB
                [78]
                # LANGUAGE_NAME=OSCRIPT
                [79]
                # LANGUAGE_NAME= REBOL
                [80]
                # LANGUAGE_NAME=REGISTRY
                [81]
                # LANGUAGE_NAME=RUST
                [82]
                # LANGUAGE_NAME=SPICE
                [83]
                # LANGUAGE_NAME=TXT2TAGS
                [84]
                # LANGUAGE_NAME=VISUALPROLOG
                [85]
                # LANGUAGE_NAME=EXTERNAL
                [255]
                # LANGUAGE_NAME=GLOBAL
                When I says customized, this just means that I changed the lines beginning with LANGUAGE_NAME=... by lines # LANGUAGE_NAME=... and I added all the languages from [50] to [85]
                However, I did not add and/or remove any abbreviation tag !
                BR
                  @guy038
                  That’s great news about A), I think I’ve seen that behavior myself once or twice when using Alt as a modifier for a hotkey that does text insert - it put a weird character in so I just removed the Alt modifier for the hotkey chord. I’m glad Tab works for you!
                  ONE NOTE: Maybe I should have made this clearer - the ‘#LANGUAGE_NAME’ needs to be NO SPACES between the hash “#” and the “LANGUAGE_NAME”. I see in your example, you’ve put a space between. If you remove the space, everything should work as expected - you should not see them as expansions in the Options dialog.
                  Sorry for the confusion.
                  Also, thanks for the breakdown in A) about the character insertions based on modifiers and encoding - very helpful going forward. And thanks for your QuickText.ini file. I’ll incorporate that into future releases as well as making the QuickText.default.ini file just QuickText.ini so it should hopefully work “out of the box”.
                  I did some looking at the codebase this morning. Again my limited C++ knowledge hampers my efforts, but it looks like sorting the languages will be harder than I expected since in the Combo box of the Options dialog, the order matters when selecting a language - it returns a zero-based index which is then matched to the N++ language list (enum LangType in Notepad_plus_msgs.h, an include file from the N++ project) which itself has the same order as the LANGUAGES I use in QuickText. All this matters to match the appropriate language. I suppose a more complicated data structure to store the language ID rather than putting it in a vector array by the ID would be more visually appealing, but certainly more C++ work than I have skills for at the moment.
                  My thought behind this was to be able to add User Defined Languages instead of just adding all tags in the USER language for all user defined languages. But again, all user defined languages return an ID of 15 - they need to be differentiated by string matching the name after matching the ID of 15 - logic that QuickText and the data structure to store the language don’t yet have.
                  Finally, I was playing with DoxyIt over the weekend and like the way they do named hotspots hopping in the inserted comment text. QuickText just uses the “$” character to indicate hotspots and removes it when inserting to the document. It’d be nice to actually regex match $(.*) like in DoxyIt so QuickText could have named hotspots, but alas the code implementing the hotspot identification is just iterating character matching through the string - I’d need to redesign that as well to do a regex match and account for the additional characters.
                  I just don’t have the C++ chops to make these changes easily (although they probably are pretty straightforward for someone who knows what they’re doing in C++).
                  Cheers.
                    I’ve started learning the Visual Studio environment at work, and have a license there now; I might download the Community edition at home, and if I can find time, start looking at this plugin.
                    I was hoping over the weekend to get the first release of my Perl-driving-Notepad++ module (Win32::Mechanize::NotepadPlusPlus) into CPAN, which would have freed up my spare-mental-time for a new project, at least until I move on to the next improvements on that one. But as I was doing my final checks, I discovered that it is failing the test suite with perl v5.20 and earlier (I had developed with newer perl, and had just assumed since I had used compatible syntax that it would work back to 5.20, or even to 5.10), so my freetime is still focused on getting that working and released. Once that is released to CPAN, I will probably start trying my hand at Visual Studio-based NPP-plugin exploration at home; with my setback, it may be another week or two before I can get to that.
                    (As with @Michael-Vincent, they don’t actually pay me to do Notepad++ plugin/helper development, though a few of my simpler/quicker things, I can justify as “helping make my work more efficient in the long term”, even when they aren’t directly related to my job.)
                      As you suggested, @michael-vincent, I removed the space char between the # symbol and the string LANGUAGE_NAME. But, after saving and restarting N++, the pseudo abbreviation tags #LANGUAGE_NAME=.... still appear in dialog, when choosing the Plugins > QucikText > Options... !?
                      Luckily, it does not interfere with the abbreviation tags management of the last version 0.1.2.4 of the QuickText plugin, which remains correct ;-))
                      P.S. :
                      Actually, I just did an additional test, changing any line #LANGUAGE_NAME=.... into lines LANGUAGE_NAME=.... and, this time, these lines are not displayed in the Options dialog ;-))
