    Removing Spaces after | sysmbol
    6 Posts 5 Posters 1.5k Views 1 Watching
    • Naveen KumarN Offline
      Naveen Kumar
      aaa|bbb.xxxx_xx| 34617
      aaa|bbb.xxx_xxxx| 7111
      aaa|bbb.xxx_xxxx| 9953
      aaa|bbb.AAAA| 10858
      aaa|bbb.BBBB| 6804
      aaa|bbb.CCC| 53853
      aaa|bbb.LINK_FOLDER| 3004
      aaa|bbb.SERVICEBIXEXTRACT| 19471
        If you have Search > Replace set in Normal search mode (or Extended search mode), searching for | (vertical bar followed by space) and replacing with just the vertical bar | will do what you want.
        If you are in Regular Expression search mode, then the | has special meaning, and you have to escape it as \| in the Find what: box.
        You might benefit from reading the official “Searching” document, especially the sections on Extended Search Mode and Regular Expressions.
        • Prahlad-Makwana4145P Offline
          Prahlad-Makwana4145
          Hello, @Naveen-Kumar
          Please follow this steps,To Removing Spaces after | sysmbol
          Step 1 :- select all the data (Ctrl+A).
          Step 2 :- Then select Edit>Blank Operation>Trim trilling space.
          Step 3 :- Remove all the spaces in between.
          Step 4 :- Then you could use a simple regular expression search and replace.
          I hope this step will be usefull for you.
          Thank you.
            Alan Kilborn @Prahlad-Makwana4145
            I won’t downvote, but I will comment for any future readers that your “solution” doesn’t make any sense.
            • astrosofistaA Offline
              astrosofista
              Hi:
              OK, just for the non-regex oriented people in the list, let me suggest you an alternative approach to delete those unwanted blank spaces.
              This little thingy requires the BetterMultiSelection plugin to get the job done, as follows:
              giphy
              In case you couldn’t read the instructions while the gif is playing:
              1. Insert a multi-selection ( Click, Shift + Alt + Down Arrow )
              2. Press the End key
              3. Then, Control + Left Arrow
              4. Finally, press Back-Space.
                astrosofista @astrosofista
                Sorry people, here is the working link to the animated gif (couldn’t edit it in time):
                https://giphy.com/gifs/eKh1aKIxZOEUB2308F
                @astrosofista said in Removing Spaces after | sysmbol:
                Hi:
                giphy
