    Multi-cursor editing
    53 Posts 8 Posters 26.9k Views 2 Watching
      Alan Kilborn @astrosofista
      @astrosofista
      Apparently the script is treating the . as the regular expression for “any single character”. Thus, when the script is run with only a . character selected, you get a blinking (if so configured) caret at every position in the doc. This script modification corrects it:
      from Npp import editor
      first_line = editor.getFirstVisibleLine()
      editor.setSearchFlags(0)          # <---------- the new line
      editor.setTarget(0, editor.getTextLength())
      editor.multipleSelectAddEach()
      editor.rotateSelection()
      editor.setFirstVisibleLine(first_line)
      I’m not sure of the complete set of possible arguments to .setSearchFlags() – it is not documented so well in the P.S. docs–but I found these in the Notepad++ source code:
      #define SCFIND_NONE 0x0
      #define SCFIND_WHOLEWORD 0x2
      #define SCFIND_MATCHCASE 0x4
      #define SCFIND_WORDSTART 0x00100000
      #define SCFIND_REGEXP 0x00200000
      #define SCFIND_POSIX 0x00400000
      #define SCFIND_CXX11REGEX 0x00800000
      My modification to the script is using SCFIND_NONE.
      astrosofistaA 1 Reply Last reply Reply Quote 2
      • astrosofistaA Offline
        astrosofista @Alan Kilborn
        Definitively regex, or at least some of its functions are invoked in the original PS. I typed an \s at the end of the first paragraph —I mean the GNU License sample text—, then selected the backslash, run the script, then the s and the script… PS ignored single characters and only take into consideration whole words, so when I selected the first T, PS did nothing, but This was selected and PS correctly matched the other two instances of the word.
        Anyway, the script modification you provided solved the issue. A big thanks for your assistance and fast reply.
        Best Regards.
          Ekopalypse
          @astrosofista @Alan-Kilborn
          Thanks for testing and improving.
          I haven’t noticed it yet but it makes sense.
          The documentation for searchFlags is described here.
          Alan KilbornA astrosofistaA 2 Replies Last reply Reply Quote 2
            Alan Kilborn @Ekopalypse
            @Ekopalypse said in Multi-cursor editing:
            Yes but that documentation falls flat when you need an actual number to pass to a function!
            Is there some Python magic one can do to find these identifiers? What I mean is, if I do dir(MENUCOMMAND) in the P.S. console, I see:
            >>> dir(MENUCOMMAND)
            ['CLEAN_RECENT_FILE_LIST', 'EDIT_AUTOCOMPLETE', 'EDIT_AUTOCOMPLETE_CURRENTFILE', 'EDIT_AUTOCOMPLETE_PATH', 'EDIT_BEGINENDSELECT', ...
            Some similar way of finding these “SCFIND_” things?
              Ekopalypse @Alan Kilborn
              for readability you normally use FINDOPTION.NONE instead of the 0.
              In order to get all values from such enum you can call its values method.
              For example: FINDOPTION.values() would return
              {0: Npp.FINDOPTION.NONE, 1048576: Npp.FINDOPTION.WORDSTART, 2: Npp.FINDOPTION.WHOLEWORD, 4: Npp.FINDOPTION.MATCHCASE, 2097152: Npp.FINDOPTION.REGEXP, 8388608: Npp.FINDOPTION.CXX11REGEX, 4194304: Npp.FINDOPTION.POSIX}
              Alan KilbornA 2 Replies Last reply Reply Quote 2
                Yes, but you have to know that EXISTS first! :-)
                To your point about “readability”…that’s why I was asking.
                I would much rather NOT use the magic number of zero.
                I didn’t see anything that logically links FINDOPTION to the SCFIND nomenclature. Maybe I missed the connection.
                  Just a slight note for any future readers:
                  FINDOPTION.values() at the Pythonscript console yields:
                  >> FINDOPTION.values()
                    File "<console>", line 1, in <module>
                  TypeError: 'dict' object is not callable
                  The proper thing to do is FINDOPTION.values (no parentheses).
                    Ekopalypse
                    Ooopps - you are right, thx for reporting.
                    Seems I have wrapped it incorrectly with my python3 plugin.
                    Yes, not every enum has really the same, but most of the time similar, name as the normal c-headers have.
                    To get all the enums you can run globals() in the console or from a script.
                      my python3 plugin.
                      gimme, Gimme, GIMME! :-)
                        Ekopalypse
                        I’m sorry, but it’s still an alpha version.
                        As long as not all functions/methods work as described
                        you’re not really gonna enjoy it.
                        Had a nasty plugin crash yesterday because instead using
                        an signed integer I used an unsigned one. :-(
                        But there will be fewer and fewer open issues.
                        And since I was wrong with the release date several times,
                        I prefer not to give a forecast until when a beta version can be expected.
                        The actual situation, Corona, has one advantage - I have more time to work on PySnack (That’s what I want to call it).
                          astrosofista @Ekopalypse
                          Glad to be of help. Let me know if more tests are needed.
                          Best Regards.
                          • Michael VincentM Offline
                            Michael Vincent @dail
                            @dail said in Multi-cursor editing:
                            I use BetterMultiSelection
                            As do I - along with SurroundSelection and DoxyIt. Do you still support DoxyIt, I submitted a pull request a little while back.
                            Cheers.
                            dailD 1 Reply Last reply Reply Quote 0
                            • dailD Offline
                              dail @Michael Vincent
                              @Michael-Vincent
                              Personally I haven’t used DoxyIt in years. I wouldnt say it’s not supported, just my interest is quite lacking.
                              In light of recent circumstances I find myself with copious amounts of free time currently, so I will make it a point to take a look at your PR soon.
