    explorer.dll. The specified module could not be found.
    34 Posts 6 Posters 13.2k Views 2 Watching
      PeterJones @Carlos Zhang
      @Carlos-Zhang said in explorer.dll. The specified module could not be found.:
      I meant the same message except the path.
      I’m sorry for misunderstanding.
      INFO: Could not find files for the given pattern(s).
      I thought it might show something else, which would have made it easier to debug. But alas, it did not.
      Please make sure you try @cmeriaux’s suggestion of procMonitor, which can precisely identify the location of the DLL Notepad++ is really trying to load. And please make sure you try my suggestion #2 of renaming the DLL and its folder.
      Carlos ZhangC 1 Reply Last reply Reply Quote 0
      • Carlos ZhangC Offline
        Carlos Zhang @cmeriaux
        @cmeriaux said in explorer.dll. The specified module could not be found.:
        Here is a screenshot of procMonitor which could be tricky to use.
        I happen to have another tool Process Hacker which can also find dlls.
        • C Offline
          cmeriaux @Carlos Zhang
          I don’t think this is the same goal.
          ProcMonitor will say which DDL notepad++ querys on plugin loading.
          Process hacker will say which one is in use but in your situation , explorer.dll is not loaded, so it’s not in use. You’ll wont find it in process hacker
          Carlos ZhangC 2 Replies Last reply Reply Quote 2
            Suggestion:
            OP is doing too much thinking and this is a problem because his thinking is counter-productive to the thinking of the people trying to help him.
            OP needs to do (exactly and only) what the helpers are suggesting, and report back clear results.
            That’s the only way this is going to get solved for the OP. My 2c.
              Hi, @peterjones and All,
              Sorry to answer only now, but my wife and I spent the big weekend of May 1st doing some interior renovations, in our living room !
              I also got problems with the plugin explorer.dll ( v1.8.8.0 - x86 - 222,720 bytes ) !
              When I started N++, I was told that This application could not be start as MSVCP140.dll could not be found ! I started searching with the Dependency Walker software and it happened that all the following DLL were missing to get explorer.dll to work properly !
              ********************************| Module List |*********************************
              * Legend: D  Delay Load Module   ?  Missing Module           6  64-bit Module  *
              *         *  Dynamic Module      !  Invalid Module                             *
              *                                E  Import/Export Mismatch or Load Failure     *
                     Module                                 File Time Stamp   Link Time Stamp   File Size   Attr.  Link Checksum  Real Checksum  CPU  Subsystem  Symbols     Preferred Base  Actual Base  Virtual Size  Load Order  File Ver         Product Ver      Image Ver  Linker Ver  OS Ver  Subsystem Ver
              [ ? ]  API-MS-WIN-CRT-CONVERT-L1-1-0.DLL      Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-ENVIRONMENT-L1-1-0.DLL  Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-FILESYSTEM-L1-1-0.DLL   Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-HEAP-L1-1-0.DLL         Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-LOCALE-L1-1-0.DLL       Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-MATH-L1-1-0.DLL         Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-MULTIBYTE-L1-1-0.DLL    Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-RUNTIME-L1-1-0.DLL      Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-STDIO-L1-1-0.DLL        Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-STRING-L1-1-0.DLL       Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-TIME-L1-1-0.DLL         Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  API-MS-WIN-CRT-UTILITY-L1-1-0.DLL      Error opening file. Le fichier spécifié est introuvable (2).
              [ ? ]  VCRUNTIME140.DLL                       Error opening file. Le fichier spécifié est introuvable (2).
              [D? ]  CONCRT140.DLL                          Error opening file. Le fichier spécifié est introuvable (2).
              [D? ]  IESHIMS.DLL                            Error opening file. Le fichier spécifié est introuvable (2).
              [D? ]  WER.DLL                                Error opening file. Le fichier spécifié est introuvable (2).
              ************************************| Log |*************************************
              Error: At least one required implicit or forwarded dependency was not found.
              Warning: At least one delay-load dependency module was not found.
              Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
              However, after download and installation of the missing dll, either, in system32 folder or in ...\Plugins\Explorer, I always got the same message This application could not be start as MSVCP140.dll could not be found :-((.
              Luckily, the next day, I found out the solution ! As my Win WP SP3 laptop is quite an antiquity, when rebuilding the OS, after a C partition crash, in 2018, I simply had installed the Microsoft Visual C++ 2013 Redistribuable x86
              So I decided to upgrade and downloaded the Microsoft Visual C++ Redistributable for Visual Studio 2015. As the requirements include Win XP SP3, even if VS2015 is not present, and that some hardware specifications were OK, I ran the executable and restarted my laptop.
              And…, miraculously, after starting notepad++, no more error message and the Explorer plugin was well installed and fully functional ;-))
              Carlos ZhangC 1 Reply Last reply Reply Quote 3
                Ekopalypse
                @guy038
                hmmm - interesting approach - I guess you are on the right track.
                  Carlos Zhang @PeterJones
                  @PeterJones said in explorer.dll. The specified module could not be found.:
                  Yes I did. Please see above.
                    Sorry, it looked so much like the post above that I didn’t notice the picture was different. My bad.
                    It does not look like Windows is trying to load the wrong DLL when Notepad++ requests Explorer.dll / MyExplorer.dll. So, that’s good news … but also not helpful, unfortunately. :-(
                    My next guess would be that @guy038 is on the right track: try to download the most recent “Microsoft Visual C++ Redistributable”: I believe that this MS page has the most recent versions of the redistributables. Since you are on 64bit OS, but using 32bit applications, I would suggest installing both the x86 and the x64 versions from the 2015/2017/2019 section at the top.
                    If that isn’t sufficient, since you do have a 64bit OS, try downloading the 64bit Notepad++ portable zipfile, and unzip it to your desktop. Try to install the Explorer plugin in the 64bit (using Plugins Admin), and see if that one works better for you.
                        Carlos Zhang @Carlos Zhang
                          Here you are.
                            Carlos Zhang @guy038
                            @guy038 said in explorer.dll. The specified module could not be found.:
                            I downloaded the Microsoft Visual C++ Redistributable for Visual Studio 2015, 2017 and 2019 for x86 from
                            https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads.
                            It really miraculously solved the issue.
                            Thanks all for the great help!!
                            PeterJonesP 1 Reply Last reply Reply Quote 5
                              I am glad it solved the issue for you.
                              But it wasn’t a miracle: if the plugin has a dependency on the MSVC++ Redistributable, then that dependency must be satisfied in order to run. Unfortunately, plugins don’t always advertise that requirement.
                              I have submitted an issue #12 and PR #15 to fix oviradoi’s README to include that requirement.
                                Plugins > Open Plugins Folder: Nothing happened. File Manager did not open.
                                I also fixed this by this page:
                                https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system
                                FYI.
                                • BernoulliBoxB BernoulliBox referenced this topic on
