    BUG: NPP Crashes when menu bar hidden and right click
    4 Posts 3 Posters 925 Views
    • SyhndS Offline
      Syhnd
      I have a crash report but I didn’t know where to write it, so I put it here…
      It happens when I hide the menu bar in the settings, close the settings and go back to NPP,
      At this stage, if I right click anywhere on the window, NPP crashes.
      Am I the only one to have this bug?
      Kindly.
        Ekopalypse @Syhnd
        @Syhnd
        no, does not happen to me.
        Can you please post your debug info which is available
        from the ? menu, the last menu item?
        In addition, test if this happens when starting npp without plugins.
        • SyhndS Offline
          Syhnd
          I found out that it was the MenuIcons plugin that was responsible of the crash.
          Deleted it, it now works as intended.
          Thanks for the help!
          Juan de DiosJ 1 Reply Last reply Reply Quote 1
          • Juan de DiosJ Offline
            Juan de Dios @Syhnd
            @Syhnd Thank you! Deleting the MenuIcons plugin fixed npp crashing for me.
